Question about Western Digital Computers & Internet
Hibernation partition My Western Digital External Hard Drive just went into status 'Hibernation Partition'. My computer doesn't seem to detect it any more in the computer menu. It is to been seen at disk manager. How do I undo this hibernation partition so I can get into my files again?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Make sure you have the HDD in the same state as it was on Hibernating. If it was removed after Hibernation, it will not be 'seen' by the PC. Everything that was connected during Hibernation MUST be connected again when starting the machine so the O/S can follow the route.
Posted on Nov 22, 2013
5 Suggested Answers
PauldLucky
  • 268 Answers
SOURCE: Acomdata external hard drive
No ned to check in that.
The external hard drive can be fomatted by :
Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
Right click on the drive you will get the popup menu.
In that select the format option.
But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
Use the full format option.
Wait for sometime, until the format is completed.
Then you are good to go.
Good Luck.
Live, Love, Laugh.
Posted on May 09, 2008
Vish2
  • 74 Answers
SOURCE: Partition error
Try using the command FDISK /mbr. This should fix the master boot record. If not, then if you don't care about the data on your drive, you could wipe it clean with any of the several utilities available on the web and then try partitioning it. Search for "Wipe Disk" in Google.
Posted on Sep 28, 2007
SOURCE: My Book Essential does not show on My Computer - Can't access files.
Had the same problem with my wd book weeks days after the warranty went out. still no solution
Posted on Aug 14, 2008
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
Posted on Jul 24, 2009
Doesn't work, cable problem, don't recognize
Get another lead
Some external storage devices work poorly or not at all when connected to a hub; try connecting the drive directly to a port on the computer. Also check if it's detected in "Disk Management". Here you can verify if the partition and format are correct for the Operating System. Check the Drive's status in Device manager. This will verify if the external drive has a drive letter designation. Check Partition and Format. Log in as Administrator account in windows or any other account with administrative privileges Insert your removable disk into the USB port. Click Start, right click on computer and select manage. Now, click Disk Management. Check whether drive letter for the device is present. Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc). If the device is detected with a drive letter, verify that no other device is using that drive letter. If it is, change it to unused drive letter. Hope this helps.
Jan 09, 2013 | Toshiba Canvio E05A050CAU3XW 500 GB...
How to initialise hard disk
You should be able to do this through your operating system utilities, i.e. if using Windows (XP, Vista or 7) ensure that the Western Digital My Book drive is connected and recognised in My Computer, then either right-click on the drive and take the option to Format the drive, or else, right click on My Computer and select 'Manage' then open the Disk Management service and select your action from the right-click menu for the external drive from there.
An alternative would be to use a third-party utility such as Easeus Partition Manager Home which is free for non-commercial use, available from http://www.partition-tool.com/
Dec 09, 2011 | Western Digital My Book Essential 1TB...
I would like to install windows xp on the hp hdx9150. But Sata disks are not recognised. So i find a driver for that, i can give to the systeme with touh F6 , wind cd-rom windows xp bigin to install
According to your problem first check the hard drive status and make sure that it is ok. If it doesn't detect in bios setup then you can change the cable of the hard drive. Also make sure that the DVD Rom working fine. If the hard drive doesn't detect while you begin setup then clear the bios first. Then reset the bios properly. You may need a firmware update also. If you can not continue the setup then break the partition of the hard drive. You can use partition break up software, like partition magic etc also. If it doesn't solve your problem then you may need to replace the hard drive. To check the hard drive status you can try with another OS installation. Best of luck.
Aug 05, 2011 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
Drive only reports 56gb to partition - missing 100gb! How do I access the remaining space?
Click Start
Right-mouse click "My Computer".
Click "Manage".
Expand the "Storage" part of the tree.
Click "Disk Management".
View the diagram for your disk-drive.
Does it show the 56GB partition, followed by 100GB of "unallocated" space,
or does it show one (approximately) 160GB partition?
If the former, backup all the files in the partition (copy to an external disk-drive, or copied to DVD-recordable disks, or to another computer).
Then, use "Disk Management" to delete that "small" partition, and to define a new partition that "spans" the entire volume, and to initialize the partition.
Then, copy the "saved" files back onto the drive.
Dec 18, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
Windows xp crashes when western digital hard drive is plugged in
i wish i knew the answer, i am having the same problem. i have switched ALL of my toshiba computer power settings to no stand-by, no hibernation, no automatic shut down (as this was suggested) and windows xp still turns into a blank screen just a few seconds after plugging this in. hard drive too strong for my 3.5 year old computer? not sure, but this is beyond ridiculous.
Jun 15, 2010 | Western Digital My Passport Essential...
Wd external hard drive stopped working
Sounds like you need to create a new partition, and if you find that a partition already exists, delete it and create another.
Jan 03, 2010 | Western Digital Elements powered by WD 320...
Mac not Reconize my MyBook
load the driver for mac use, the external hard drive comes with cd, the mac driver should be inside, load it to your mac computer. if you donot have the cd go online to western digital and download it. just load the driver and u will be fine, make sure u connect the cable in right places.
Mar 09, 2009 | Western Digital My Book Essential Edition...
External hdd not detected in my computer but is in device manager
You probably still need to partition it, before you can even format it.
Try the disk manager in Windows.
In the start menu, right-click "My Computer" and in the popup menu, select "Manage".
One computer management comes up, select disk management and there you should see the disk. You can then create a partition and format it.
Jules
Mar 01, 2009 | Western Digital Passport WDXML800UE...
Western digital Scorpio 120 G
Actually there is no solution, the hard drive is bad.
What I ended doing was recording the partition in iso. ( I had a Factory Partition)
Got a new hard drive 160G scorpio unfortunately it does not come with installation disc.
Installed Vista, and with vista created a partition and then installed the contents of the factory partition.
Feb 18, 2009 | Western Digital Scorpio WD1200BEVS 120 GB...
Wiped out partition on WD500GB My Book
Try using a recovery utility like Acronis or R-Studio. I have used R-Studio alot and it always comes through for me. The drive will be recognised but no drive letter will be assigned. Run the programme and after it scans the drive, select what you want to save and save it to another drive or partition.
That should do it.
Cheers.
Dec 22, 2008 | Western Digital 500GB My Book World...
Computers & Internet Logo
65 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
