Question about HTC Sensation XE
Dead phone - HTC sensation XE
I was using internet pass-through and updating a few applications via Google play store when my phone switched itself off. It did switch back on, but, while I was adjusting the time and date , it switched off again and is not switching back on since. Its neither getting charged. Could it be a motherboard issue? or software related issue?
It could maybe be a dead battery. Maybe you should try replacing the battery?
Posted on Nov 22, 2013
  • Parul
    Parul Nov 23, 2013
    Tried, it didn't help . :(
5 Suggested Answers
270rexton
  • 762 Answers
SOURCE: My HTC TOUCH - Phone Off on the Screen, how do i switch it back ON?
Try hard reset, mostly it helps.
Posted on May 30, 2009
  • 2069 Answers
SOURCE: I have a HTC HD2.
you should try to have it opened and inspected for mostly water damage. all those indicate to a fault motherboard. some components are shorting and causing the battery drainage.
this will require disassembling phone and be sure, this is a hardware problem not software.
regards
Posted on Jan 31, 2011
JCCinema
  • 95 Answers
SOURCE: hi, phone has been switching
You need to perform a hard reset. Unfortunately you will lose all data you have on the device. Please remove your microSD card to salvage the files saved on there after performing the reset.
Follow these instructions:
Hard Reset
  1. Remove the battery and replace it.
  2. Press and hold the Volume Button
  3. Press and hold the Power Button until the phone powers on.
  4. You should see a simple menu showing options such as Fastbook, Recovery, Clear Storage and Simlock.
  5. Using the Volume Down button to navigate, Highlight Clear Storage
  6. Press the Power Button to select Clear Storage
  7. Confirm your decision with Volume Up for Yes. If you feel like backing out, press Volume Down.
This will return your phone to it's original, out-of-the-box condition, software-wise.
If even, after the Hard Reset your phone still reboots, contact your Customer Service department for a warranty replacement.
Posted on Jun 03, 2011
  • 4 Answers
SOURCE: Htc sensation weather widget not updating
have you check your internet connection ?
Posted on Jul 06, 2012
How do I update the Google play store app
  1. Turn the phone off, wait a bit, and turn it back on. Do this outside or near a window for best results.
  2. Check your phone Settings. Is Wi-Fi enabled? Is Data enabled? If you don't have at least one of these enabled, you won't receive updates. If you only have Wi-Fi enabled, you will only receive updates when you are connected to the internet via Wi-Fi.
  3. Check Apps in your phone Settings. Make sure the Google Play Store app is enabled.
  4. Check the settings within the App itself. You can set the app to update automatically.
  • Launch the Play Store app.
  • In the upper left corner, touch the three horizontal bars next to Google Play.
  • Touch Settings (near the bottom).
  • Touch Auto-update apps and select one of the choices. I have mine set to "Auto-update apps over Wi-Fi only."
If none of this works, contact your provider.
I hope this helps!
Mar 29, 2015 | Tablets & eReaders
Why is it that when ever I try to download games 50mb or higher on the Google play store I get an error (911). Please help I really want games like boom beach.
There is not one sure solution for these market related android errors and you'll have to try a bunch of fixes to fix these errors and chances are that the errors will come back and you'd have to repeat the process. The 911 error mostly occurs when you are trying to update your apps in the Google play store while connected to a faulty wifi network.
Method 1: Clear the Google Play store data
  • Go to Settings >> Manage Applications or Apps >> Open "All" tab
  • From the list of "All" apps >> Scroll Down and Select "Play Store" >> Select Force stop, Clear cache and Clear data
Method 2: If you are using a wifi connection that requires a webpage login, then your authentication has probably expired. Log in to the APN again via your android browser. Open Google Play store and run the app update again . If that didn't work the problem is with the wifi network itself.
Method 3: Simply switch to another Wifi network and run the update. The error 911 should disappear for the new Wifi network.
Method 4:
Use your mobile network data services instead of wifi. Turn wifi off and then turn your data on and now open your Google Play Store and download/update your apps or games. However, this method is only suited for apps and games that are small sized. For larger updates you should use your wifi network to save data charge.
Jul 19, 2014 | Video Game Consoles & Games
How do i update my adobe flash player to version 11 on my htc evo design from boost mobile
Through the Google Play Store is the only way I know of. If it isn't working go into settings > Apps > play store, clear out cache and force stop the play store. Then try updating flash again.
Dec 04, 2012 | HTC Flash Any Evo 3d,evo 4g,evo Design,evo...
How can i download viber to my HTC sense phone?
Use Google Play to search Viber on your phone or use this link
folu.me/viber
Oct 19, 2012 | HTC Sensation Cellular Phone with Sense...
I connect my htc sensation xl to the pc and its not working, instead my phone turns very hot
Whenever you connect HTC Sensation XL with Beats Audio to a computer using the USB cable, the Choose a connection type screen opens and lets you choose the type of USB connection.Select one of the following choices, and then tap Done:Charge onlySelect this option if you only want to charge the battery while connected to your computer.Disk driveSelect this mode when you want to copy files between HTC Sensation XL with Beats Audio and your computer.
When on Disk drive mode, you will not be able to use apps on HTC Sensation XL with Beats Audio that access the storage such asCamera.
HTC SyncSelect this option to synchronize contacts, calendar, and other information between your computer and HTC Sensation XL with Beats Audio.USB tetheringWhen you do not have an Internet connection on your computer, you can select this mode to share the mobile data connection of HTC Sensation XL with Beats Audio with your computer.Internet pass-throughIf you don't have a data plan or you don't have access to a Wi-Fi network, you can select this mode to share your computer's Internet connection with HTC Sensation XL with Beats Audio.
Oct 10, 2012 | HTC Sensation XL X315E with Beats Audio...
Unlocking phone
Hi, You can unlock a HTC SENSATION XE safer and easier using unlock code. You can get the unlock code for a HTC SENSATION XE from http://www.unlock-zone.com/htc-sensation-xe/rs5wp9/ at affordable cost.
UNLOCKING STEPS FOR HTC SENSATION XE
1. Switch ON your HTC Sensation XE with a Not ACCEPTED SIM Card.
2. If your HTC Sensation XE asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Sensation XE will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Sensation XE is now unlocked
Sep 29, 2012 | HTC Sensation XE with Beats Audio Sim-Free...
Htc sensation wont turn on it vibrates 7 times but wont do any thing else
i have the similar problem, i have recently updated my sensation to ice cream sandwich, and while running the application the htc froze. I took the battery off and put it back still no response. the phone vibrates as its turning on but the screen still stays blank. I have been to few forums and this problems seems to be recent as alot of htc sensation users have the similar problem in the last month.
May 05, 2012 | HTC Sensation 4G
HTC Sensation XE Logo
52 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
