Question about Michele Watches Michele Releve Diamond Watch, 38mm
I have a retired Michele watch and I'm looking for the gold metal strap to fit it. The model number is MS18EE246710 anyone know where I can find one?
Anyone happen to know what battery i need to replace in an Invicta gmt pro diver model 6995 ? Gold plated, with black polyurethane straps .
I believe this watch has a Ronda powertech 515 quartz movement, which requires a 371 (SR920SW) battery.
May 27, 2016 | Invicta Watches
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
TX T3B891 INSTRUCTION MANUAL
Anyone know how to fit a new battery in a watch its a TX model number: T3B891
Jul 14, 2012 | TX Technoluxury 770 Fly-back Chronograph -...
I have a Bulova Watch that was given to a Clark Candy employee with a Serial Number of 523791. Looking for what year it was made and is it worth anything
The value of your watch depends greatly on the model / style, age, and case composition. It goes without saying, but watches (of any mechanical quality) that have real gold cases right now are worth quite a bit more than watches with gold plated, gold filled, gold-tone, or stainless steel cases. Presentation watches like those given to employees upon retirement were often gold or gold-filled--but there's a world of difference in value between those two types of watches.
In terms of age, it's much easier to date vintage Bulova watches by their "year code" than by their serial number. If you look carefully, usually above or below the serial number, you'll see a little alphanumeric code, like L5, N3, or P6. These can be translated as follows:
Lx = 195x Mx = 196x Nx = 197x Px = 198x Tx = 199x
Pre-1947 Bulova watches used little symbols to show the year of manufacture. A picture of those codes can be found here, as well as elsewhere on the Internet:
http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
Jul 24, 2011 | Bulova Watches
Cerruti watch strap cannot be changed in any watch specialists in middlesbrough and i am just wondering where i will be able to get it done
You probably will have to send it away to get sorted (make sure you send it insured and very well protected).
You should contact cerruti to see who the repair shop is in the UK, (not sure they have one.)
Failing that you may be able to buy a replacement strap of ebay and have a general watch shop change strap for you.
Or find a jewellers that sell straps, they should have one that fits.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Cerruti 1881 Watch
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
Info/site for 90 year old Dreadnought watch
the strap is normally not "cloth", it should be thin gold bracelet type.
most of them i've seen are from around 1912-1930.
yours maybe similar to the one below, but it's difficult without seeing the watch.
http://www.bidorbuy.co.za/item/261641707/Collectable_Vintage_9ct_Gold_Dreadnought_Ladies_Watch.html
Apr 25, 2017 | Watches
WV-57H Watch - how do you replace the strap? I have a new strap for this model and can't work out how to take the old one off and fit the replacement. Thanks
If you look at the watch from the side, you'll see that there's a two-part metal piece on the underside of the watch on each side.  The metal piece is a spring-loaded pin going through the strap which is holding on a larger metal piece.  You need to get another small pin (or an eyeglass screwdriver might work) so you can poke in the end of that spring loaded metal piece, which will allow you to slip off the larger metal bracer.  Then you can poke the spring-loaded pin entirely out of the strap and it will be freed entirely.
To help you visualize what you are doing, the spring-loaded pin operates similarly to a toilet-paper roll - you need to compress the pin so you can slip off the larger metal bit, then take out the pin, which will free the strap.
Oct 30, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Michele ladies watch
Anyone who says they can't open your watch is NOT a repairman. Take it to a mom and pop repairman, NOT a big store, because most of the big stores send all their repairs out to someone like the mom and pop store. If you still have problems finding someone please feel free to get ahold of me and I will assist you. Good Luck!!
Jul 20, 2008 | Michele 71-750-cc-322-102l Wrist Watch
Watch strap
Please call this number 1-718-7298600 x 272, order a strap for kc1232, usually it takes you 7 days to receive this strap, and there will be four new screws comes with your order, I believe it cost you $18.00 to have new strap.
Tsai
Jan 19, 2008 | Kenneth Cole KC1232 Wrist Watch
Michele Watches Michele Releve Diamond Watch, 38mm Logo
24 people viewed this question
Top Michele Watches Watches Experts
Jimmy Accardi
Are you a Michele Watches Watch Expert? Answer questions, earn points and help others
