Question about Stanley STA-J45C09 450 Watt Jump Starter with Compressor
Support manuals and diagrams
Motor runs but does not generate any pressure. Product was left on for 8 hours by mistake which caused the problem.
  • 32 Answers
Im guessinga the compressor hasand no pressure. Its probably burnt up. Those are single cylinder oil less compressors ment for momentary use only. Best thing to do is get another one.
Posted on Nov 26, 2013
What weight oil does a 5550 watt take?
According to Generac for there Portable generators they recommend, Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter. Here is a link to get a manual if you need one. You will need your model number.
http://www.generac.com/service-support/product-support-lookup
Jan 30, 2016 | Generac Electrical Supplies
I need a owners manual
Owner's Manual - Northern Tool + Equipment
www.northerntool.com/.../manuals/166114.p...
Northern Tool + EquipmentOtherwise, back feed from the generator into the power grid could kill utility workers...... information, always refer to the engine Owner's Manual furnished with thegenerator. .... (a) Hard-starting motors require 3-5 times the rated running watts.
Online Product Support - Generac Power Systems, Inc.
www.generac.com/.../product-support-lookup
Generac Power SystemsOr how about a new hose for your pressure washer? Shop and buy genuine Generacparts and accessories for your home backup generator, portable generator ...
[PDF]Owner's Manual - Home Depot
www.homedepot.com/.../66508163-2ff4-4048-9162-0...
The Home DepotThis manual contains important information that you need to know and understand in ...Power Output. This generator is not designed to power sensitive electronic equipment... Do not touch electrically energized parts of the generator and.
[PDF]Owner's Manual - Smarter Tools
Jan 21, 2016 | Electrical Supplies
Clomagenerator How often do i need to change oil if I run it 8hr a day
Looks like you're playing with a Coleman Generator.
Here's a link for the manual, all you need is the model # of your unit.
http://www.powermate.com/productmanuals.php?cat_id=3
On my gas generator I change the oil every 100 hours, but I don't run it the way you're using yours.
100 hours divided by 8 hours per day would be 12 days which could be evry 2 weeks. That might be a bit often. See what the manual recommends.
Jul 20, 2015 | Cars & Trucks
Why does my generator stop working in the middle of the nights?
Hi Evans
The usual cause is lack of fuel. Most generators only run about 8 hours maximum on a half-load of electric capacity.
-Steve
May 15, 2015 | Electrical Supplies
Generator alarm underspeed
When you get the under speed alarm is the generator under load? Try manually starting the generator with no load and let it run for a while, if no alarm, then put it under your home load and measure current draw (maybe have an electrician check it) if the amp draw and in rush caused by compressors, pumps motors etc are within the generator rating, check your fuel pressure, on average 8-11 WC Nat gas. Pressure may test well under no load but drop starving the engine of fuel unde rload. Underspeed is just that engine cannot make RPM/Frequency
Nov 28, 2013 | Generac Power Systems Generac 5522 14 Kw...
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
Hi, I appreciate your wiring diagram for the Oreck XL motor --but it is too small to read. Could you send me a readable copy. Thanks very much for your help! Nels Klyver
Print out the diagram u have, then scan it and blow it up to a larger size (all scanner allow u to enlarge the image), this is what I do with hard to read electrical diagrams.
Apr 28, 2009 | Vacuums
Product mistake!
click on my profile........top right side....now look on top left side edit profile...scroll down and remove the picture and browse and upload the new photo/ object
Mar 08, 2009 | Apple iPod mini 2nd generation MP3 Player
Vehicle Parts & Accessories Logo
108 people viewed this question
Top Stanley Vehicle Parts & Accessories Experts
David Payne
David Payne
BJ Russell
baire
Are you a Stanley Vehicle Part and Accessory Expert? Answer questions, earn points and help others
