Question about Car Audio & Video
How many whats do apine bass vr music max 500 get
What are some best cheapest bass amp under 500$?
'Best' and 'Cheapest' are seldom in the same category, but have a read of these links.
12 Best Subwoofer Amplifiers for Your Car or Truck - BestProducts.com
www.bestproducts.com/cars/parts/g662/subwoofer-amplifiers-for-your-car/
  1. Cached
  2. Similar
Jul 19, 2016 - If you want big bass, choosing the right subwoofer is only half the battle. Be the loudest car on the block with the help of these new mono amplifiers for your car or truck. ... 14 Best Rubber Floor Mats for Your Car or Truck.
Best Car Amplifier 2016 ' Top Rated Auto Amplifiers - CarAudioNow
https://www.caraudionow.com/best-car-amplifiers/
  1. Cached
Looking for the Best Car Amplifier of 2016? ... And if you are going to add a subwoofer, a monoblock amp is an absolute necessity. ..... Two-channel A/B ZRX516.2, 500 watts; Four-channel A/B ZRX616.4, 600 watts; Four-channel ... (PCBs) that can perform under the most rigid and extreme conditions attesting to the brand's ...
Bass Packages Under $500 at Crutchfield.com
www.crutchfield.com > ... > Car Audio, Video & GPS > Car Subwoofers & Boxes
  1. Cached
Under $500 - Shop for Bass Packages with the help of real A/V experts. ... package includes Magna Bass MB212P mono amplifier (250 watts x 1 at 4 ohms) and ...
Can you guys recommend me a combo amp under $500? ' TalkBass.com
https://www.talkbass.com > ... > General Forums [BG] > Amps and Cabs [BG]
  1. Cached
Jan 19, 2012 - Hey guys, I'm currently in middleschool and I need a new amp thats preferably 400-500 watts, but under $500. We currently have a bassist, ...
Need good advice on a sub+amp combo, $500ish budget - Car Audio ...
www.caraudio.com > Forum > Car Audio Discussion > Subwoofers
  1. Cached
  2. Similar
Oct 13, 2012 - 12 posts - ‎1 author I'm new to both the forum and somewhat new to car audio in general so please excuse any ... So i need a great sub and amp to complement them for around $500. ..... other subs for under 200 bucks id rther have over type r
World Record Budget Build w/ Drew Wesley's $500 Car Audio System ...
z? 2:32 https://www.youtube.com/watch?v=NOatL_DzZL0
  1. Similar
Oct 3, 2013 - Uploaded by EXOabigdeal World Record Budget Build w/ Drew Wesley's $500 Car Audio System ' 4 12" VVME Subs & Bass Amps ...
Top 10 Best Car Amplifiers To Buy for 2016 - MyCarNeedsThis
mycarneedsthis.com/todays-best-car-amplifiers/
  1. Cached
Whether you're looking for an amplifier to power your entire cars component speaker ... power outputs come in 3 settings (of 800 watts, 500 wats, and 300 watts ). ... Rockford Fosgate R750-10 Class D 4-Channel Subwoofer Amplifier ... Talk about power when it comes to getting some serious knocking under the trunk.
Oct 30, 2016 | Car Audio & Video
Powersupply won't run on Orange terror Bass 500
I found both FDA2828N50F MOSFET transistors in the power supply were shorted. I replaced them and the amp worked fine. I couldn't find a reason for them to fail.
Jan 10, 2013 | Orange Amps Orange Terror Bass 500 Amp...
I have two sp2 speakers i am using a ipod numark dj machine connected through my 2600 watt peavey amp it keeps blowing out one speaker can you tell me why
The SP2 speakers are rated at 1000 watts PROGRAM which is around 500 watts RMS MAXIMUM. You should be using an amp capable of a maximum of 500 watts a side... Your amp is WAY too big. You will have to throttle it down. The speakers have the protection for the tweeters but NOT for the woofers. At five hundred watts RMS and 8 ohms the current is: P = I^2 * R so I^2 = 500/8 = 62.5 so MAX current is 7.9 amps. I recommend you put a 8 amp FAST BLOW fuse in the speaker leads. If the fuse blows, you have saved another speaker and you are DRIVING them too hard. For greater safety make the fuse a 7.5 amp fast blow. Also get a sound meter. The max on these speakers is 125 Db at a meter distance... and in your venue you should NOT exceed 100 Db to be safe with the OSHA regulations regarding hearing protection... I suspect you are driving the speakers too hard. One side may be getting more bass. The speakers are rated down to 55 Hz. DO NOT boost bass up as you will overheat the speakers. If you are using microphones, be careful of feedback, especially that above hearing range. If you need real low bass, then get an 18 inch subwoofer. No matter, stay within safe sound levels to avoid lawsuits and hearing loss... I know several deaf musicians...
Jul 07, 2011 | Music
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Apr 22, 2011 | Peavey Electronics Peavey Max 112 Bass...
For 100 watts it doesn't seem that loud to me. Could I maybe add more speakers (2x10s)?
Our human perception of loudness can be way off. You should get a soundmeter and compare. There are some pretty good ones on eBay new for about $140.
Adding speakers may NOT increase the sound much as the power will then be split between the speakers.
Nov 02, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Pioneer DJM 500 Ch 2 Bass Controller
The bass pot's / controls are notorious for becoming dry jointed, all that is usually needed is the controls resoldering.
http://www.technicsdjuk.com/
Apr 01, 2009 | Pioneer DJm500 Professional DJ Mixer...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
