Question about Sony Televison & Video
5 Blink Sony KDL - 46HXZ729
My Sony KDL-46HX729 Will blink the red light 5 times, then continue to repeat 5 times after a very short delay. How can I fix this. I cannot find any component labels as Q705 732 761 or any boards labeled A B C or anything that like that. Which seems to be the answer most people give.
    New Friend:
Samsung46inch led tv no on which control si no manual
Posted on Nov 22, 2013
  • 98 Answers
SOURCE: TV won't power on, repeating doulbe red light blink
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Posted on Jan 24, 2009
SOURCE: Sony Grand vega 55" will blink green for three times than red
Your problem is your thermal fuse.It is located around the bottom of the compartment that houses the lamp. You will have to remove the lamp and take the bottom back panel off. Then you will have to remove the fan. I ordered the thermal fuse so I would know what I was looking for when I started to replace it. If you take your time and are patient enough you can fix it yourself. I fixed mine and it's working great.GOOD LUCK!!!
Posted on Jun 23, 2009
SOURCE: KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Posted on Sep 14, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: sony kdl-40s2000 won't stay on and blink red 4 times
I think the problem is the t-con board, Part #
1-789-499-11, cost about $200.
Posted on Apr 20, 2010
welcomejee
  • 10594 Answers
SOURCE: I have a sony KDF-E55A20
In KDF-E55A20, 6 times red light blinking shows that there is not output of *DD 6Volt* in GM board (power supply)
Check power supply board connectors that seems lose or it has some lose solder connections.
Thanks.
Posted on Sep 07, 2010
Sony Bravia KDL-60EX500 no longer turns on.
Refer to Sony KDL 55EX500 Troubleshooting Manual Protection Mode Symptom...
5X Blink - TCON & HFR Failure
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board.
First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
see schematics in Sony KDL 55EX500 Troubleshooting Manual Page 23
Sep 15, 2016 | Sony Bravia Kdl-60ex500 60" Inch 120hz...
The light blinks red continuously on my kdf55e2000 sony tv
Hello, does it blink in a pattern (example:blink 4 times pause and repeat 4 time blink)? Please let me know. tks
Nov 01, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
Red standby light go on when I turn on mt Sony bravia
set should have a blink or error code of some type if set does not work--count red and or any other lights blink sequence---3 blinks, 5 blinks etc.
May 14, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony KDL-32V2500 : It comes on and after few seconds the red light blinks 4 times, then stops and then starts blinking all over again.
This is sort of a generic answer but I found this info about Sony blink codes. Hope it helps!
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Problem with Sony Bravia 46" TV (Model
blow out fan in mother board tower mother is over heating and not geting enough of air leting the mane chips over heating makes computer stop so it doesnt catch fire.
Feb 22, 2011 | Sony KDL-46S2010 46 in. LCD Television
Red light blinks twice tv doesn't come on
Sony Blinking Codes:
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Try checking the power supply,
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 15, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
