Question about Gestetner DSc332 Copier
Tech imagerunner had working scanner ondsc332, changed settings on computer no longer scanning
    Novelist:
  • 112 Answers
Hi, I will solve your problem i just require a little bit of extra information.
1:Your current OS(operating system for example win xp,vista,7 of 8)
2:Your System type.(easy way to find it is press 'Ctrl+Alt+Del' go to task manager, at the left top on the menus at File>New Task(run) write cmd click OK or press ENTER then your cmd will apear just write wmic os get osarchitecture. The results can only be 32bit, 64bit(32bit can also be 86bit)).
3:More or less what you changed only if possible.
My email : markusmaritz333@gmail.com.
I will send you step by step instructions how to fix your problem.Im hoping to hear from you.
Please rate me. Thanks
Posted on Nov 22, 2013
I have a cannon printer that I always could scan with my old computer. I have a new laptop and I don't know how to make it scan now.
Yeah, something changed and some older scanners do not work with new OS and hardware. Fortunately new printer/scanners are not very expensive. I think the programming standards changed in terms of scanners. One cool option of new stuff is wireless printing and scanning, so this means that you no longer have to go to the host (sharing ) system to scan, but you can scan and control from the laptop. I prefer HP. Set up works fairly easily, but you do need to have access codes for your router. FOLLOW install directions EXACTLY, and specifically NOT plug an play.
Oct 03, 2010 | Office Equipment & Supplies
How do I scan on the Canon imageRUNNER 3300
instalation of photocopier/scanner with pc model no IR-3300. Kindly tell me the procedure to install it and make it functioning...
Mar 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Hp 3670 no longer scans to computer with vista 32 bit upgrade. Scanner will only scan out copies to printer. worked fine with windows xp
You can use Paint or a similar program to scan in a picture/document with your scanner.
Once in Paint you can select from Open the option of From Scanner.
You can change the size to fit the page in Paint and then save it to a file which can be opened and sent to a printer.
It's very basic, of course and it doesn't give you the options to set the scanner options usually found in the HP Toolbox.
Jan 31, 2010 | HP ScanJet 3670 Flatbed Scanner
Canon ImageRunner 2016 - scanner Not working properly
Ir 2016, can be onlly pull scanner, so that means that you must have installed scan gear, selected in scan gear, and over microsoft word or similar insert scan ( INSERT PICTURE FROM SCANNER OR CAMERA ), but the machine must be in scan mode, put original on platen or dadf, and then "pull it"from PC.
Hope that helped
pls.rate
Sep 30, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
I want to instal drivers for printer and scanner
just do a search on www.canon.com.au for your print driver and scanner driver its on on there do a search on there if you need to.
regards
canon tech
Apr 01, 2009 | Canon imageRUNNER C3200 Copier
Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Jan 02, 2009 | Canon imageRUNNER 5000 Copier
The buttons on the Scanner itself will no longer work.
You should be able to reconfigure the button settings by clicking on the "Settings" button in the CanoScan Toolbox application. Although the default setting is Scan, Copy and eMail, each of the buttons can be configured to do whatever operation you choose.
Oct 13, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
May 28, 2008 | Canon imageRUNNER 5000 Copier
Canon Imagerunner 3570 - has stopped scanning
Try to reload the machine system software as it may be corrupted due to the power outage if this does not solve the problem the harddrive may be damaged just as its possable for a computer harddrive to be damaged if you do not shut your computer down and just pull the plug out.If you need any more help please get back to me or phone 00447764303923 i am in the uk
Feb 18, 2008 | Canon imageRUNNER 3570 Copier
Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Sep 21, 2007 | Canon imageRUNNER 1023N Black and White...
26 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
