Question about Comfort Zone CZ7007 Oil Filled Electric Radiator Heater
My heater does not get hot - Comfort Zone CZ7007 Oil Filled Electric Radiator Heater
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
It is themosta, overheat protector , or bad plugin
Posted on Nov 23, 2013
No hot water , no heater
No Hot Water - Electric Water Heater Troubleshooting
www.whirlpoolwaterheaters.com/owner-center/.../no-hot-water/
Whirlpool's video explaining potential reasons your water heater is not working ... Troubleshooting and Repair · No Hot Water (Video) · Replacing a Heating ...
Electric Water Heater Repair and Troubleshooting ' Whirlpool
www.whirlpoolwaterheaters.com/owner.../troubleshooting-repair/
Troubleshooting and Repair of a Standard Electric Water Heater. No Hot Water ... Not getting power is a common reason new water heaters don't work.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
My tenant has a electric 30 gallon water tank. cimarron by Reheem. model ... So if u notice your water is overly hot and then notice no hot water ...
Dec 26, 2015 | Water Water Heaters
The heater is blowing cold air when on hot setting, thermostat replaced?
Could be a few problems causing this. Check to see if both heater hoses are hot going into and coming out of the heater core from under the hood. If both hoses are hot then there is an issue with the blend door/s inside the heater box assembly. If only 1 hose hot at the heater core and the other hose warm/cool you most likely have a heater core restriction and a back flush will be required. If no hoses are hot at the heater core then you have air in the system or the coolant level is low
May 10, 2015 | Cars & Trucks
Cold water connection is hot
Did you put hot to hot side? And cold to cold side?
Cold water pipe usually has shut-off valve.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Add comment and say brand and type of water heater for possible follow-up
Mar 23, 2013 | RELIANCE ELECTRIC WATER HEATER
2000 chevy silverado not blowing hot air
1: not enough liquid in the system (air in the heater core)
2: inoperative heater valve not allowing hot liquid into the core
3: hot/cold blend door in the heater box stuck on cold
4: clogged heater core
A clogged heater core will have one hot hose and one significantly cooler hose at the firewall connection; easily tested by hand. a good core will have both hoses very hot to the touch when the heater is on full blast.
Make sure that the system is full and at operating temperature, and the heater controls set on full heat. Feel the hoses at the firewall; if they are both too hot to touch then the problem is in the heater box or controls.
Mar 03, 2013 | Cars & Trucks
The heater isn't putting out hot air
check to see if there is plenty of antifreeze in radiator , may have a air bubble in system .
Jan 28, 2013 | 2005 Chevrolet TrailBlazer
What if the heater hose going in is hot and the heater hose coming out is cold.the heater will blow cold air
Possibly the heater core is 90% blocked. open enough to draw hot water in, (hose feels hot) but not enough volume to provide heat from very cold air, 10% hot water gets cold quick, coming from core..
Flush heater core in reverse direction - cold side in hot side out..
Just a theory..
Dec 14, 2010 | 2000 Chevrolet Silverado
No water comes out of the hot side of my shower or bathtub
Based on gas prices, often gas hot water heaters can be a more cost-effective option than electric models and preferred by many homeowners. However, gas hot water heater models can have their own set of problems that differ from electric versions. You will not find it difficult to perform some basic troubleshooting to resolve an issue with a gas hot water heater.
Instructions
  1. 1 Determine if the gas supply has been shut off. No gas will cause the hot water heater to stop producing hot water. Turning the gas supply back on should be your first troubleshooting technique.
  2. 2 Check the pilot light. If you are experiencing no hot water, the pilot light of your gas hot water heater may have distinguished. Turn off the gas source and place a match over the pilot light tube to relight it.
  3. 3 Adjust the thermostat of your hot water heater. If you find that the hot water runs out quickly or does not get hot enough, you may need to set the temperature of the gas hot water heater higher. Typically, set the dial between the medium and hot setting for adequate hot water.
  4. 4 Inspect the gas hot water heater. The burner orifice and flue can both become clogged on a hot water heater. Turn off the gas and use a wire brush to clean out any debris that may have become lodged in these sections.
  5. 5 Ensure that all the burner access covers are in place. If the pilot light will not stay lit, it could be due to exposure to drafts.
  6. 6 Flush the tank. Certain deposits can build up over time when using a gas hot water heater which can cause the tank to produce a banging noise. To flush it, turn the heater off and open the pressure relief valve and drain valve on the water heater. Use a hose to flush water through the system until the hose runs clear.
Thanks.
Oct 15, 2010 | Kohler Home
I have replaced my electric water heater and I have checked everything I can think of and I still run out of hot water in 3 minutes. What on earth is the problem.
3 minutes?? does the water run cold then? or just warm?
Is this what the tank you replaced was doing? If so, then you may have: 1 a recirculating pump instant hot water system thats faulty and allowing cold water backflow into hot water piping. 2 A tempering valve that has stuck, allowing cold water into your hot water system.
Or maybe a broken or missing dip tube in your new heater.
If after 3 minutes the water is coming cold out leave that faucet running and go to heater and feel the hot water outlet pipe from the heater. if that pipe is hot then the heater is not the problem. If the hot pipe from the heater is cold the heater is the problem. (Make sure the cold pipe coming into the heater is connected to the Right side marked "cold" !) If there is a tempering valve by the heater: feel the output from the tempering valve, if it is cold and the pipe from the heater to the tempering valve is hot, then the tempering valve is the problem. If all these are OK somewhere in your plumbing system hot and cold may be connected possibly a faucet or showerhead that is shut off at the spout/head, but hot/cold handles are left turned on then cold water can backflow thru hot pipe.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Size and installation for instant water heater
Ariston gl4.0 should be fine if used inline with your hot water heater. Used alone it will likely run out when dishwasher is filling and you are using sink.To use your existing hot water for backup: 1 connect existing HOT water line to cold (inlet) on ariston, 2 Then HOT (outlet) from ariston to sink and dw. If you want instant hot water at a sink 10 feet away: use 3/8 pex pipe from ariston to sink, so you only have to run off a cupful or 2 before hot water arrives at sink.
Aug 30, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Comfort Zone CZ7007 Oil Filled Electric Radiator Heater Logo
102 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
