Question about Olympus E-520 Digital Camera
Hard reset Olympus E-520
My new camera (bought off of Ebay) is not working well when trying to take action photos indoors. I wanted to try a factory reset, but in the list of functions, that choice is "grayed out". ?? Can I do a "hard reset"?? Thanks!
  • 34 Answers
1. Select P on the mode dial.
2. Open the card door and turn on the camera.
3. Hold down the Menu and the OK buttons at the same time for 5 seconds.
4. Olympus E-520 is displayed.
5. Release and again hold down the Menu and the OK buttons at the same time for another 5 seconds.
6. Reset has been done is displayed
7. Press the OK button.
8. Shut the camera off
Posted on Nov 24, 2013
  • Shannon M
    Shannon M Nov 25, 2013
    Thank you!
neta
  • 852 Answers
SOURCE: Controls problem -factory reset?
you need to get a copy of CD that comes with your camera. It has the factory settings you are lookin for. If you go to Olympus site im sure they would be glad to help. (NOTE) The paperback manual does (NOT) include factory settings.
Posted on Sep 12, 2005
SOURCE: Vista not recognising Olympus camera on USB connection
I just spoke to Olympus Tech Support.
You have to download Olympus Master 2. (Their program is no longer called Camedia Master.)
http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp
At their main site, search for olympus master 2.
Posted on Apr 02, 2008
jackboy
  • 2985 Answers
SOURCE: can't transfer photos
Remove the Camera software'
Windows does not need it- it can do it all by its self.
Posted on Aug 12, 2008
  • 919 Answers
SOURCE: E-volt 500 Olympus camera will not work well on most settings.
Turn the camera mode dial to P - press Menu button - camera 1 tab is highlighted - right arrow over to Card Setup - down arrow to custom reset setting - right arrow to reset and press Ok - highlight Yes and press Ok. The camera should be back in factory defaults.
Posted on Dec 24, 2008
SOURCE: My Olympus FE-310 has battery problems!
I have the same model and I sort of took a page out of Solution #2.
I don't have electronic technician experience so I took one main insight: The Poor Design of the Conduction in the bottom cover.
Here's what I did: I took some Copper Wire (mine came from the wire you use to hang paintings) and some Aluminum Foil.
Next I wrapped the Copper Wire with the Foil. The piece was roughly slightly bigger than 1/2 of a Postage Stamp.
Then I inserted this metal square over the batteries and closed the cover.
I found that I could take more shots without the camera saying Battery Empty.
See if this works. So far it's touchy but it's been taking more photos than before.
Posted on Oct 28, 2009
When i take pictures they show with a pink color? i reset the camera to factory settings but still same pink pics advise?
This FE-340 Olympus is a great camera. Lots of features and usually great results
  • Indoor pictures with flash set on auto WB (white balance) should not be a problem
  • Indoor pictures without flash requires setting the WB to match the light source in the room (incandescent, florescent etc) Outdoor pictures WB on auto generally not a problem
For more help Include a photo with the metadata of the photo from the image data file
Dec 02, 2015 | Olympus FE-340 Digital Camera
Olympus C-765 - won't take photos anymore. Memory card is fine and camera has worked perfectly for the past two years. Does anybody have a solution? The camera seems to function as normal, but when I press...
Reset the menus to default or factory settings.
Then test the camera again.
Make sure that the battery is fully charged or new.
You might consider to buy a new battery (Ebay is a good place) for this camera. Then test.
Problems like this can show up when the battery is weak or not fully charged.
You may try to remove the battery for 24 hours and then after try it again.
Apr 15, 2010 | Olympus Camedia C-765 Digital Camera
Whenever I want to take pictures indoors, i a have
try using another setting for the flash: red eye reduction or when needed.
also try to use another scene setting. most cameras have an indoor setting.
Jan 22, 2010 | Olympus E-520 Digital Camera
Blurry Photos when using indoor or auto mode on Olympus IR-300
make sure lens is clean and be sure to use flash indoors, try using a tripod or setting camera on something and see if the results are any better
May 14, 2009 | Olympus i:robe IR-300 Digital Camera
Olympus e520 will not turn on
try to rest your camera and see if that works
Apr 20, 2009 | Olympus E-520 Digital Camera with 14-42mm...
Olympus D 555 Blurred action shots
Indoor actions in low-to-moderate light are very difficult. This is why professional photographers pay thousands for DSLRs with high quality high-ISO settings, and thousands more for big and heavy lenses that can shoot with a large aperture (small f-stop number) to get the most light into the lens and onto the sensor.
Your Olympus D-555 only goes to ISO 400, which is not suitable for indoor action shots, and the lens is f/3 to f/5 which is not a fast lens. What you are trying to do is simply not possible with this camera. You need good quality at ISO 1600 (or higher) and f/2.8 or faster for the lens. This will give you 8 to 16 times as much light gathering capability in low light situations, letting you use a much faster shutter to capture action shots in low light.
Dec 30, 2008 | Olympus ImageLink D-555 Zoom Digital...
Dec 23, 2008 | Olympus Cameras
Green colour showing through photos??
Okay I called Olympus and they told me to try to reset the camera. I know you have tried using the reset option already from the meun, but apparently if you open the battery door, leave it open and hold down the Menu button and the okay button at the same time, it will (as the olympus guy called it) do a hard reset. This should restore the screen back to what he refered to as the factory settings. After you do that shut the battery door, and turn the camera off. Then turn it back on and you should be in business. it didn't work for me, but that is because mine was apparently sold to be after it was the floor model ( I had no clue). I have since returned it for a full refund. I thought I would pass on that the olympus help support people said.
Jan 18, 2008 | Olympus Stylus 790SW Digital Camera
Olympus E-520 Digital Camera Logo
496 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
