Question about Panasonic Viera TH-50PZ80U Plasma TV
Vierra tv, model TCL47ET5. TV no longer connects using wifi to AirPort Extreme router. Router works for iPhones and ipad. Tried hardwire connection with Ethernet cable and tv can access internet. Still won't connect wirelessly.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Have you tried unplugging it and plugging it in again?
Posted on Nov 22, 2013
4 Suggested Answers
Ragoney
  • 158 Answers
SOURCE: I have a panasonic TX-L37G20B
that should be it for wired connection, unless you have problems with getting a connection from your router. try to turn it off then on (tv)
Posted on Mar 23, 2011
  • 8457 Answers
SOURCE: Wifi i have a wifi
Yes,Wifi internet signal dose not require any connection to the tv all.Read ur tv owner manual how to activate ur tv Wifi internet signal out that all.This tv it is a internet ready compatible tv wright?
Posted on Jun 11, 2011
dduncan774
  • 760 Answers
SOURCE: connecting ipad2 with hmdi cable, tv freezes and releases every few minutes
These two products are not compatible.
Posted on Jun 20, 2012
What is the password they ask for to connect wifi to tv
There's a WiFi password that you entered when connected your devices to the router. Put it in TV.
May 13, 2015 | Gateway Computers & Internet
How to get apple extreme to communicate with windows 7
Hi
Apple Airport Router:
Orange flashing is showing No Connection.
Green LED is functioning with a connection.
Reset the Router by using a paper clip in the round tiny hole on the back. Hold clik button in for 3-5 seconds with router powered on.
Remove power & reconnect.
After a router reset (above) the router should be available on it\'s factory settings (see manual) or show up in the e.g. Settings / WiFi as a selectable choice. An iPhone (Settings / WiFi) is ideal for this. Click on the name to choose it & enter factory password etc.
To make it even easier, you can use the Airport Utility App on your iPhone or iPad to set the Router up for your network settings.
Apple make this pretty easy to set up compared to other routers.
Other Method:
You can use a Browser (e.g. Safari, Firefox, IE etc) to access the IP address of any router from any computer. But first you must know the IP address (or the factory assigned IP address after a reset) currently assigned to the router. This could be on the back or bottom or in the manual that came with the unit.
Connect the router to a computer via an Ethernet cable. Type the address into the URL box and hit return. (The IP address will look like eg. 192.168.1.1 or 10.0.0.xxx. Type this into the URL entry box instead of say xxx.com./">www.xxx.com. )
If the IP address is correct, the Routers Menu will show up in the browser asking for a Password. (The Router factory Password is in the manual.
Enter the routers password or factory password.
Once you have the routers internal menu in the browser screen you can Find the SSID and give it a name for your Home Network rather than the cryptic factory default. You can set the Router password to your choice (use WAP2)
You can set the WiFi Channel number to a less used channel for your suburb (less busy=faster access). You can assign a new IP address to the device. (Use the 192.168.1.xxx or 10.xxx.xxx.xxx group number that is made available for the public). You will also have to enter the IP address of your Internet Service Provider and a password for your ISP Account. If you don\'t have your ISP\'s preferred DNS IP handy then you can enter 208.67.222.222 or 8.8.8.8. (I found these give 20ms faster response)
Use the SAVE button on the screen to save your settings. This will take a minute and restart with the new settings. You should be set to go.
Once you have it all working.... don\'t forget to copy all the settings onto paper for future reference. On a Mac, just press Cmd Shift 4 and draw a box around the menu settings. This will end up as a screen shot on the Desktop. This saves a lot of writing. Rename the screen shots to something meaningful. (e.g. My Router Settings Page1)
Good Luck
Trevor
May 24, 2014 | Apple AirPort Extreme Router
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
Comcast ipad wifi problem
I'm sure you've done this but try turning off wifi on iPad and then turning back on. Does your wifi name show?
Jun 17, 2017 | Apple iPad 32 GB 3G Tablet PC
My iPad won't connect to Airport Extreme WiFi
Is your A P E a hidden network?, if so just type in the name of your router name and scan, it will find and ask for a password
Apr 28, 2012 | Apple AirPort Extreme Router
MA073LL/A wifi but no internet
Thanks Habour castl for letting us and future people having a similar problem know that the firewall settings was the cause of the internet not working through your router.
May 17, 2017 | Apple AirPort Extreme Base (MA073LL/A)...
Apple airport extreme stopped sending out a signal. no wifi pick up on any comp phone or ipad light is flashing amber. did a reset unplugged rest again noting
Go to your Airport utility, if you do not have it. download it in the app store. use the wizard setting, it will find your probles
Jul 03, 2011 | Apple AirPort Extreme Base Station Router
Airport extreme that is constantly flashing green
yes if only one location has this problem, the airport has now top security level because of latest theaths. it's normal.
Dec 29, 2009 | Apple AirPort Extreme Router
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Panasonic Viera TH-50PZ80U Plasma TV Logo
166 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
