Question about Grilling
Jenn air c201
The fan comes on and will not go off - it comes on with elements and not with the grill
  • 66 Answers
SOURCE: Jenn Air Not Exhausting During Grilling
is this down draft cook top or give me the m# thanks
Posted on Jan 14, 2008
aborcass
  • 2651 Answers
SOURCE: Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Posted on Mar 16, 2008
ButtFuzz
  • 463 Answers
SOURCE: outdoor grill igniter not firing
The actual ignition unit itself (not the battery) is dead.
Posted on Feb 27, 2009
SOURCE: jenn air propane grill conversion
It is inconceivable to me that large manufacturers like Jenn-Air and Nexgrill can jointly make and sell an expensive grill and then completely abandon the consumer. I purchased an Jenn-Air 740-0142 LPG and like so many wanted to convert to nautural gas which requires a larger gas orifice. I spent a month on the internet and phone calling Jenn-Air and finally Nexgrill who actually manufactured the unit in China. The Jenn-Air and Nexgrill serial numbers are the same. the 740 prefix is LPG and the 750 prefix is natural gas. After three calls to Nexgrill I found a manager who actually acknowledged making Jenn-Air but declined selling me parts for it as I believe they have product liability concerns. I call back as a Nexgrill owner and finally ordered natural gas orifices at $10.00 each. The shipment never showed up. Calling back again I was told that they really didnt really have any orifices in stock but could sell me the entire replacement gas valve for $28.00 which I purchased. The valves actually arrived on the shipping receipt was from The Grill Services in City of Industry 909-718-6128 www.grillservices.com . Part number 750-0141/142/593/594.
Forget about pirates in Somalia... we have them right here. Shame on you Jenn-Air and Nextgrill.
Posted on May 31, 2009
  • 8404 Answers
SOURCE: I have a Jenn-Air Model C201-C.
One - clean the fan
two - maybe. For positive answer, check with your dealer
Posted on Oct 15, 2009
Bosch oven temp control
If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
Mar 23, 2013 | Bosch Ovens
Can you confirm if the top element should be coming on when selecting just fan oven? If had a look at the over selector switch all appears to be of ok with the switch selecting the top element as well as...
Correct, the grill element should not come on when using the fan oven.
Using the fan oven
The air inside the oven is heated by the
element around the fan situated behind the
back panel. The fan circulates hot air to
maintain an even temperature inside the oven.
HOWEVER
I think you are doing this
Using Hot Air Grilling
This function uses both the grill element and the
fan. Turn the function control knob to the
appropriate position. To achieve optimum
cooking results, it is advisable to place the oven
shelf in the middle position while the oven tray
should be inserted at the bottom.
IMPORTANT: When using the hot air grilling
function, set the thermostat knob no higher
than 175°C, which is between the 150°C and
200°C setting, to avoid overheating the front
of the appliance.
The door MUST be closed while Hot Air
Grilling.
http://kitchen.manualsonline.com/manuals/mfg/zanussi/zcm930x.html?p=10
Dec 01, 2017 | Zanussi ZCM930X Dual Fuel (Electric and...
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
Grill Element
I believe this is working as designed! The downdraft fan always turns on when I run my own grill!
Oct 20, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Cooking element
Hello
If the grilling elements does not get hot enough, then the main reasons for that are:
Escessive air movement across the grill.
Surface controls may not be properly set.
and the voltage maybe low.
But if is not getting hot at all then you can check by exchainging the elements to see if it is the element itself, and if it is the element then you will need to replace it.
I hope this help!!
If you need to replace it I know a place that are very cheap for Jenn-Air parts and super fast delivery...Let me know.
Eddie rentas
Tupper Lake
Jul 13, 2008 | Jenn-Air JED7430 Electric Cooktop
Jenn-Air 30in. Exaust problem
liquid spill and alarm won't go off.
Mar 21, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Mar 15, 2008 | Cooktops
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
