Question about Hitachi Video Cameras
User manual for dst box hdr5to1 - Hitachi Video Cameras
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
Apr 21, 2016 | Sony ICF-C318 Dream Machine Alarm Clock...
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
Daylight savings time change casio atomic watch has not changed is there a way to change it manually
An example for G-shock: I searched for casio g-shock manual and got this: http://world.casio.com/wat/download/en/manual/
You enter model from back of watch and it gives you a searchable PDF manual.
For mine, model 2638 (and likely most G-shocks), you press and hold the upper left (Adjust) button until the City Code flashes. You then press the lower left (Mode) to enter DST mode then press the lower right (Receive) as it cycles through On, Off and Auto.
On moves 1 hour forward, Off moves 1 hour back. After you select, you press the upper left button (Adjust) twice and it's set. I would not pick Auto anymore as my watch is still set to the original DST days which were changed in the US years ago and no longer match, I don't believe the DST days used can be changed by the user and I don't believe Auto receive adjusts for DST.
Mar 13, 2011 | Casio Watches
We have 2 DZS400 digital tork timers. unfortumately when DST days were changed we have not been able to use the automated dst transition and must manually change the clocks twice each year. is there a way...
DZS400 product descriptor shows DST, and many other programming options:
1) This might help or not:
You can modify DST start & end times > Press MODE until dSt shows > Press MONTH, DATE, DAY to modify start times, and then press ENTER. (or press DEL and ENTER to delete) > Press MONTH, DAY, DATE to modify end times, and the press ENTER > press MODE to return to AUTO.
2) According to DZS400 product descriptor "The controller has 365 day holiday capabilities with 24 single dates" ... if above solution doesn't work, the 24 single dates might provide enough days to fill in programming gaps in the DST. Your manual should have programming steps.
Sep 18, 2010 | TORK Hardware & Accessories
I have 2 clocks (model 40009,40010)that have inaccurate time
I read the manual which said to depress the alarm button. That wasn't the right button but I found that depressing the button next to it, the DST button, that that fixed the problem.
Thanks.
Oct 24, 2009 | Equity Time USA 30731 LED Digital Electric...
Need a copy of the instruction manual
how to manually tune a digital set top box tcl dst 8313
May 10, 2009 | Televison & Video
DST on MTG900
The MTG-900 supports automatic DST which can be activated in the time setting mode.  However, the ROM in the MTG-900 dates from before Congress (in their infinite ability to make mistakes) modified the DST schedule, so, instead of switching at the beginning of April and the end of October (as currently specified), it switches at the end of April and the beginning of October (as previously specified).
I do not believe that there is a way to change the DST scheduling or manually turn DST on or off.  I've resorted to changing the time zone manually and turning off the DST feature.  IOW, I set the timezone to Pacific (LAX) during PST, and, to Mountain (DEN) during PDT.
Mar 10, 2009 | Casio Atomic-Solar MTG900 Watch
How do I get the wave ceptor to come on ?Casio-2688
Try Googling (casio)(2688)(manual) without parens for instructions.
May 08, 2017 | Casio Watches
Correct Time Zone
Using the Emerson CKD5809C manual (also with SmartSet(tm) ), try Zone 4. TIME ZONE button: "04".
Zone 1: Atlantic Time
Zone 2: Easter Time (Default)
Zone 3: Central Time
Zone 4: Mountain Time
Zone 5: Pacific Time
Zone 6: Yukon Time
Zone 7: Hawaiian Time
Reference:
http://www.emersonelectronics.ca/emerson/en/category/list/694
or
http://www.emersonelectronics.ca/emerson/en/product/details/2361
As for disabling the Daylight Saving Time (DST) time change I have some guesses to try (not having one of these radios in my hand) or just skip to #4 below.
1. Manually setting the time and see if this disables the DST change.
2. Is there a Zone setting other than above? Like maybe a Zone 0? And then manually set the time.
3. Look at http://www.fixya.com/support/t236208-daylight_savings_time_adjustment for my solution there and try adjusting the DST Start to the same as DST End or DST Start and End with a month of 0 (if that is possible).
4. Or for the really desperate, change the Zone to 5 during DST and back to 4 during standard time (no worst off than with no DST auto setting.) (After I wrote this, I found an Emerson reference to no DST areas, Saskatchewan in this case, in the CKS1850C manual http://www.emersonelectronics.ca/emerson/en/product/details/2383, pg 9, and this is their solution.)
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Video Cameras Logo
49 people viewed this question
Top Hitachi Video Cameras Experts
mega_mind
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
