Question about Canon PIXMA MP780 All-In-One InkJet Printer
Won't print black: refuses to change form 'Fine Photo Pro' mode
Although this printer generally produces good results, it has had two faults:- 1.) after using it to print a few CDs, it will not change its default back again to A4 paper. Each time I go and change it by hand (and change default setting) it ignores me next time. 2.) it is currently refusing to change from 'Fine Photo Pro' mode, and is not outputting any text or solid black at all. I guessed I needed to update / replace the driver, but trying this hasn't worked. Any ideas?
  • SEBBY Nov 24, 2007
    Same problem as above
  • 2,427 Answers
Click on start > printer and faxes then right click on the printer and click properties
change your settings there
Posted on Dec 31, 2007
SOURCE:
Black banding 1280
Do nozzle check. Is it perfect? If only one or two nozzle missing, it must be "good result" in photo quality mode printing. But if, there is too much nozzle missing, result is no good. If nozzle check is perfect, but the result is not satisfied, check the PF scale and PF scale sensor.
Jan 26, 2013 | Epson Stylus Photo 1280 InkJet Printer
Negative type,or lost color on glossy prints.
Check your computer settings. It has programming to make Negatives like the old photo film would produce and this may be the Mode that it is set for. You could also be in the Infared Mode which would give you more strange results.
I am not an expert for this area, but I have used some of the photo programs both on my set and at the Drugstores. You could also have set your Camera, if Digital, for the wrong Mode and taken the photos in Infared or Negative Modes. The printer would not be at fault, just accurately printing the way it was recorded.
Jan 23, 2012 | Kodak Esp 3250 Allinone Multifunction ( ...
It refuses to print
dear sir good day to print you have to 1- remove the old driver from your mac 2- install the driver agin 3- do a nozzle check on the printer 4- if the mac didn't recognize the printer so you have to change the usb printer cable with a new one thank you and good luck
Jan 08, 2010 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo PX800FW doesn't print text
printer working ok-did 50 colour photos ,6x4 when i made a mistake and pushed the print button when there was still about 1 inch of the previous photo still being printed.This print emerged with overprint of about 1".Thereafter the printer has refused to operate properly the next print being heavily discoloured.It then told me to replace the light magenta cartridge-this I did and the discolouration changed hew.It then told me to change the magenta and light cyan carts.-I did and discolouration changed again.It then told me to change the yellow and cyan=siscolouration now bright
red over coloured. I then successfully printed a letter in B&W proving that the black cartridge was still working.However as soon as I tried again to print a coloured photo it now tells me that the machine does not recognise the black cartridge and orders me to change it and until I do refuses to take any instructions telling me to install the black cartridge cprrectly.The black cartridge installed isout half full and has successfully printed copies and photos.I have carried out the suggested remedies by the machine and none were effectuve.How do it the infernal machine working again???
Oct 11, 2009 | Epson Office Equipment & Supplies
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Greyscale printing
You may well be on the right track Certainly nothing to do with the printer as such It will only squirt the inks it is told to. So check the printer software[drivers] for starters- Is it possible you have the latest -check makers web site. This may also apply to your graphics card/image editor. Do ensure all the latest[current drivers and patches] are loaded. For example I Paint Shop Pro- Coral will sent updates from time to time some of which seem to be almost as big as the original program. If I have occasion to reinstall or repair the prog- I must always remember to reload the updates.
May 09, 2007 | Cannon Canon i960 Photo Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
