Question about DeLonghi VV550715 Oil Filled Electric Radiator Heater
DeLonghi TRS0815 T (1500 w) will not turn on. Is there a reset button or procedure?
Delonghi Perfecta 5500 just out of the box. The problem appeared when I plugged for firs time.
How to reset to factory default values
Caution: It will reset all menu settings and programmed
to the default values.
1. Press the "P" button to enter settings.
2. Turn the selector until "Default Values" shows.
3. Press the button to confirm.
4. The message "Confirm?" shows.
5. Press the button to confirm and exit
Dec 10, 2017 | DeLonghi Coffee Makers & Espresso Machines
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
Nov 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Defuser unit stuck at bottom of Delonghi magnifica coffee machine. Squeezing red buttons does not help. Cannot remove
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
Aug 21, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I have a Delonghi Dragon HM3 Oil Filled Radiator, its only a year and a few months old, I turned it off after using it for a few hours and now it won't turn back on. I have changed the fuse but still no...
does it have a reset button? Have you thrown a breaker to that plug in? Does that plug in work? Try plugging something else in and find out it could be as simple as a blown breaker. thats the only things I could think of
Mar 04, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
Descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Apr 22, 2010 | DeLonghi Coffee Makers & Espresso Machines
Delonghi pac w160a...''no water symbol'' stops on in airconditioning mode even though water tank is full
In the back of these units where the cord pulls out, there is usually a red reset button, try pushing that to reset the unit, also make sure the filter is clean, pulls from the top out of the unit. Make sure the coils are clean as well behind the filter.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 12, 2009 | DeLonghi Air-To-Air Portable Air...
DeLonghi Pinguino PAC-210
i just opened the back of the unit and byepasted the reset button . the wires on the reset button i toke off and jioned them with a piece of steel connectind the 2 of them together there are 3 of them i just tokk the top 1 and bottom 1 closest to yourself off and jioned them it is working fine and has been since i have done that try that i hope it works for you as it did 4 mine happy sleepin with cool air
Jun 08, 2008 | DeLonghi Pinguino PAC-210 Air Conditioner
FE Light
You need drain the water and then function normally.
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi VV550715 Oil Filled Electric Radiator Heater Logo
26 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
