Question about Uniden TCX905 Cordless Accessory Handset and Charger Phone
Will a Uniden TRU 9496 handset work with a 9466 base
Will a Uniden TRU 9496 handset work with a TRU 9466 base
5 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
Posted on May 10, 2008
SOURCE: Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Posted on Sep 29, 2008
  • 12 Answers
SOURCE: Uniden handset doesn't work
If you replaced it with a working new battery pack. You can test it in another phone. The Battery pins on the phone board could have a poor connection which requires soldering.
Posted on May 04, 2009
SOURCE: Uniden cordless phone model TRU 9466 3.5mm to 2.5mm adapter
Hi Ted,
I'm looking for a solution to a similar problem. I found this adapter that might help you: <http://www.theheadsetbuddy.com/pc-computer-headset-to-uniden-phone-adapter/>I can't vouch for it first-hand since I haven't used it but am about to purchase it. It looks like you should be able to use a headset or separate headphones and microphone with it.
--Tom
Posted on Dec 05, 2011
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
Oct 04, 2013 | Uniden Lands Phones
How can I clear the previous registrations from the TRU 9485 base?
Use the following steps to reset the base to factory settings for all TRU models:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep).
According to Uniden Tech support, this is supposedly all it takes to reset the phone.
Aug 12, 2009 | Uniden TCX905 Cordless Accessory Handset...
UNIDEN cordless charger for india
UNIDEN DOES NOT SUPPORT SERVICE IN INDIA, TRU 9466/TRU9485 WILL ONLY WORK IN THE US AND CANADA. USING ANOTHER CHARGER COULD DAMAGE THE BASE.
Feb 16, 2009 | Uniden 2.4GHz Handset
Tru 9496
SOLUTION:
Aug 07, 2008 | Uniden TCX905 Cordless Accessory Handset...
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Uniden hand set
What is the model # of your handset. It must be tcx 900 or tcx 905 to be compatible with the tru 9488. Good luck! :)
Jan 12, 2008 | Uniden TRU9488 Phone
How to deregister a handset without the base with which it orginally registered. The reason is that that based was destroyed in fire, only the handset survived. Can anything be done to make the HS become...
Uniden TRU 8888Handset Reset (De-Register): 1. Remove Battery. 2. Reconnect battery while holding down "*" and "#" key. 3. Then press the right upper soft key under the LCD. 4. Press the "End" key. 5. Phone will be ready to register to the base.
Dec 20, 2007 | Uniden Cordless Phone
Dec 19, 2007 | Uniden TRU8885 Cordless Phone
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Uniden TCX905 Cordless Accessory Handset and Charger Phone Logo
41 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
