Question about Goforsharing TurboWire
Turbowire does not have an active internet connection
How to activate facebook without wifi?
Accessing Facebook needs internet connection. Without any active connection, you will not be able to connect to internet.
Internet connection option for such devices:
Mobile phone:1. GPRS - settings will be coming from your mobile service provider, data rates will be deducted from your load credits.2. Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Laptops / computer / PSP:1. USB Dongles - this will use the gateway connection via BTS for its using the internet connection like the protocol of ISP.2. Wi-fi - Wi-fi connection - needs active wireless connection from your modem/router/gateway. Charges will be applied via ISP 9internet service provider)
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
Dec 01, 2011 | Myphone Computers & Internet
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
How can i connect internet through my cell lg gs500v
First you have to activate GPRS in your mobile, for that you need to contact with your mobile connection provider and they will send you required settings. After getting confirmation that your GPRS is activated and if you get the settings, save it in your mobile and you can connect internet.
You can also connect it to your computer with data cable or bluetooth and can browse the internet.
AV
Jun 10, 2011 | LG Computers & Internet
No internet connection
Problems that can cause this problem are :
- gprs and wap configuration was not right or not activated. Some provider of SIM card require activation via message to send activation setting to your phone. After this activation, phone usually can connect to internet automatically.
Some of SIM card will configure this setting automatically after put in a phone, but other SIM card need manual configuration. Make sure you've configure internet connection in your phone properly.
- another problem is signal strenght or continuity. If you make a connection in closed building or other place with low signal, you may can't connect to the internet.
Hope this help and be kind to rate please, thank you
(^_^)
Jan 07, 2011 | Nokia 5230 Cell Phone
Need to activate windows
If you have Internet connection, then you can Activate Windows over the Internet, if you cannot get Internet access, you can Activate Windows using the phone.
When you boot up your computer it will inform you to Activate Windows - just follow the prompts.
OR alternatively
To start the Activation process click on Start - All Programs - Activate
Dec 26, 2010 | Computers & Internet
No internet connection...
hi
there is an internet connection in nokia 5130.but it may be disabled.contact your customer care service and ask him to activate the GPRS settings. they will send you a internet settings of your mobile.kindly use that service to activate the GPRS and activate the internet connection in your mobile...
thank you
Dec 17, 2010 | Nokia 5130 Cellular Phone
I have a metra turbowire 70-1857 wiring harness, and i am lost at connecting it to my pioneer aftermarket DEH-1100MP. I have the harness hooked up to the amp in the trunk. and strung through car and in the...
well head units usually dont have just rca inputs....but the outputs can be changed to rca style with adapters. the speaker level outputs are what you need to change....good luck
Apr 25, 2010 | Metra Turbowire 70-1857
Computers & Internet Logo
48 people viewed this question
Top Goforsharing Computers & Internet Experts
David Payne
David Payne
Are you a Goforsharing Computer and Internet Expert? Answer questions, earn points and help others
