Question about Canon CanoScan LiDE 25 Flatbed Scanner
Canon Scanner DR-2080C driver and software Win7
admin734
  • 268 Answers
SOURCE: Missing the disc
Well the good news is you don't have to pick up a disc :-) . You can actually download the driver for the scanner here (the driver is the software that allows the computer to see the scanner)
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=7181
On that page you want the second one down (2080INF.exe)
Here is what you are going to need to do:
  1. Download that file
  2. Double Click on the file and then hit "Run" followed by "Unzip"
  3. Click the "Start" button
  4. Click "Control Panel"
  5. Double Click "Scanners & Camera's"
  6. On the left menu (it is the blue menu on the left) select "Add Imaging Device"
  7. A wizard will now come up , click "next"
  8. It will now ask what kind of scanner/camera you want to install, on the bottom right is a button that reads "Have Disk" ; click that
  9. Hit "Browse"
  10. Navigate to the folder where you un-zipped the original download to. By default it went to "C:/DR208C/INF" - In that folder you will see a file named "CANODR2K" , double click it.
  11. Hit "Ok"
  12. Select how it is connected (USB or SCSI)
  13. Finish the wizard
And thats it! Now your scanner is installed on the computer and you can scan......
Also on the original CD is a software called "Capture Perfect" , which is the software that is used for actually scanning with your scanner , you can download that here: http://www.softpedia.com/get/Multimedia/Graphic/Graphic-Capture/Capture-Perfect.shtml
Posted on Oct 02, 2008
  • 14 Answers
SOURCE: Canon DR-2080c - Replacing rollers
Check for a switch on the scanner that is made to feed single pages or multiple pages. If it is on single page it can multi jam all the time.
As far as the rollers go there is a pick up roller, separation roller, and a feed roller. You can clean them with rubbing alcohol to see if its indeed the tires that are bad. The exchange kit has all three tires in it that are user replaceable.
Posted on Mar 03, 2009
SOURCE: My Canon DR-2050C keeps jamming when I try to scan more than 1 page???
I finally solved my problem. Now it works like new.
Cause:
- The spring that returns the next sheet detector (small black plastic rocker arm between the two rollers on the back side) came off. So the scanner cannot detect transition from one page to the next. This spring is located inside the device and you cannot fix it from the outside.
- You know if you have this problem if you don't hear a "click" sound after each page is scanned. Without the spring attached the rocker will not return on every page. When it doesn't return the scanner think it is still on the first page and will not scan the next page. The "click" after each page is NORMAL. Without the click is the first sign your spring came off.
Solution (Only recommended for people handy with hardware and the unit is no longer under warranty)
1. Turn off power and unplug the device.
2. Pop off the plastic cover to the back of the scanner
3. Remove the screws that holds the plastic cover to the back.
4. Remove the screw by pushing on the retainer clips. DO NOT loosen any gears or motors.
5. Locate the rocker arm and re-connect the (very small) spring
6. Warning - if the LED light pipe falls out be careful how you put it back. This is a transparent widget at the top to route a LED light to the top of the device to indicate the power on status.
Sorry I didn't take pictures. If this sounds too complicated, send it to Canon for repair. Took me about a day to figure out exactly what was wrong and how to disassemble the scanner to fix it.
Good luck.
Posted on May 26, 2009
  • 196 Answers
SOURCE: I have the canon dr-1210c scanner. Software is
check first to see if ur scanner is compatible with ur windows operating system if is the next thing i would suggest in uninstalling the software the reinstalling the software.
Posted on Jul 28, 2010
  • 132 Answers
SOURCE: is there a canon dr 2080c driver for Windows 7?
look in optional updates in windows. thats the cool thing with 7
Posted on Dec 26, 2010
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
Unknown error. Canon DR-2050C/2080C Driver version 2.2.10412.07001 (-4523)
I have many years repairing Canon scanners so I hope my suggestion helps you out.
In my experience with the problem your having I have found that the bios needs to be flashed on the particular model scanner you have. You will need to contact your local canon dealer to have this done because they have diagnostic software to do this with. Also they can run the diagnostic software to tell if there are any other issues that need to be addressed on your scanner while they are there.
I hope this helps you out if not let me know.
Mar 17, 2011 | Canon DR-9080C Path-Through Scanner
How can i get capture perfect software for my canon dr 2080c?
Go to their official webpage, and try to find software... or just download this Driver Update Software for XP Vista 7 8 and make the update. I hope I have helped. Have a nice day
Paul
Jan 18, 2011 | Canon DR 2080C Path-Through Scanner
Is there a canon dr 2080c driver for Windows 7?
Dec 26, 2010 | Canon DR 2080C Path-Through Scanner
Line appearing on document
Clean the glass thoroughly with a damp cloth.
S. Mohan
Sep 30, 2009 | Canon DR 2080C Path-Through Scanner
I recently set up a new DELL optilplex 760. When I go to install my Canon DR-2080c I get an error stating "Device Not Found". I've uninstalled and reinstalled many times but still no luck. Can anyone help...
Have you installed device driver? It is just not enough if you install scanning software. Also trya different USB port o a different USB cable.
S. Mohan, India
Jun 04, 2009 | Canon DR 2080C Path-Through Scanner
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
Canon 2080C scanner software causing monitor issues
Some sort of feedback through the scanner it seems Delete the scanner software and reinstall. Check Canon website for software updates Consult the Tech support team whilst you are there
May 31, 2007 | Canon DR 2080C Path-Through Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
29 people viewed this question
old marine
old marine
