Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Pressure switch on stack washer
Were is this pressure switch on the stack washer
  • Caroca Aug 12, 2008
    my washer is draining the water to fast or maybe the water is being forced out to fast and it can't drain into the pvc pipe fast engough and water is spraying out every where from the connection that runs from the washer meets the pvc pipe
Make sure that not more that 6 inches of the drain hose is in the drain pipe. Too much hose causes a syphoning effect. Water goes into machine and then syphons out into drain.
Posted on Sep 04, 2008
    Problem Solver:
  • 15 Answers
Usually the pressure switch is next to the timer or in front.
Posted on Oct 10, 2007
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
The water does not shut off when filling the washer tub in my Kenmore stacked washer/dryer, Model No. 417.93872200. The water keeps rising and overtops the washer tub. What part(s) do I need to replace?
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Oct 13, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer overfills, dosen't stop filling even after I cut washer off
bad water level switch or the clear plastic hose has a hole in it or popped off the water level switch or the pressure switch same thing.the switch works by pressure,if there's a hole in it or the line feel off there's no pressure and the switch keeps calling for water,shut the water valve off
Jul 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Won't fill with water and goes right to wash cycle
Chech the pressure lelvel switch and hose that is connect to the pressure switch and tub
Mar 25, 2010 | Frigidaire FEX831CS Top Load Stacked...
Stack washer/dryer spilled water on floor
Sounds like you need a pressure switch, before you go and buy one, take front panel off and blow into little thin clear hose to see if the is a blockage
Jan 14, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer will not stop filling up it overflows
Very simple. No parts needed! Remove the pressure tube that connects from the water level switch down to th bottom of the tub. Blow out the trash that has accumulated in the bottom of the tub and re connect the tube to the water level switch. Drain the washer. Retry.a097efc.jpg
Dec 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Whirpool duet front load washer door trouble
I have stacked ours too, though after 5 years we have not had any issues with the pressure. I would suggest checking the screws holding the hinge in place as they may have loosened or been tightened with the door not properly lined up.
Aug 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
95 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
