Question about Microsoft Wireless Optical Notebook Mouse 4000
MS Wireless Notebook Optical Mouse 4000 won't scroll in Word 2007
I've had this mouse for a few years now and all of it's functions worked fine with Word XP (not to mention all the other Office XP programs). Just last year, I decided to upgrade just the Word program to Word 2007. Once I got the program installed, I noticed all the functions excet the vertical and side scroll works with Word 2007. The scrolling works just fine with all of my other computer programs. I'd like to figure out some kind of solution to make the scrolling work in the program. Is there a setting I can change to get it to scroll in Word 2007?
  • 1 more comment
  • chen5stars May 07, 2009
    I appreciate the help. The exception button is called settings under the buttons tab on my computer. I didn't even realize what that was until you told posted a solution. I had to try a few different configurations for the scroll button, but I eventually got it to work. Thanks for the help Dudeman321.
    I take back what I said. I don'tsee a mouse manager in the add/remove programs and adding an exception didn't work, if that settings button is the exception button. I'm still having problems getting it to scroll
    Finally got the scroll working. I don't know how, but it is. Thanks.
  • 233 Answers
1. Goto COntrol Panel > Mouse properties
2. Then goto wheel tab - exception
3. Then add the programs that arent working.
4. Click apply then ok.
If you don't have the exception area in the mouse properties. Then goto add/remove programs and remove the mouse manager that came with the mouse.
One of these solutions should fix your problem.
Posted on May 07, 2009
  • 1 more comment
  • Dudeman321 May 07, 2009
    No probs glad to help
    Look for the intellipoint software in the add/remove programs list if its there get rid of it.
    Maybe you needed to reboot after adding those exceptions? The only thing that can really create this problem is a mouse manager. So the solution is to either setup an exception e.g. the manager is not used for those programs or remove the manager altogether. The problem is its not always clear which program is the mouse manager as its not just called that. On my laptop its the "Synaptics pointing device driver"
SOURCE:
My Microsoft wireless mouse just stopped working on my HP 550 laptop. All lights are on--no obvious problem I can see. (Wireless notebook optical mouse)
Try downloading the driver in your computer again. The registry file can be corrupt from other downloads. It has happened to mine twice so far in two years The drivers can be found at this link below...Remember I do not know what model you have so a 3000 & a 4000 model link for each are showing for you below here
http://www.softwaredriverdownload.com/microsoft_wireless_notebook_optical_mouse_3000_driver.html
http://www.driverfiles.net/Input-Devices/Microsoft/Wireless-Notebook-Optical-Mouse-4000/download/page,sh,28746,138,20,.html
Jul 15, 2010 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless notebook optical mouse quit working
You may have a bad mouse.
Try the mouse on another computer. Since it's a microsoft product it should install automatically just fine. It'll either work or it won't If it doesn't call Microsoft. The mouse has a warranty and MS will replace it. I was in a similar situation with a MS mouse and they sent me a new device. I did not have to send the bad device in and I got the replacement in a couple of days.
Mar 06, 2010 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless mouse 4000 doesnt select tabs/icons
Normal 0 Try disconnecting the camera from the USB port and reinstall the CD software program that came with the mouse. When the program asks you to connect the camera to the USB port, do so and it should work. Hope this helps. Bud
Jan 21, 2009 | Microsoft Wireless Optical Notebook Mouse...
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Jan 20, 2009 | Computers & Internet
MS Optical Mouse 4000 problem; computer mouse pad no longer functional
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Aug 08, 2008 | Microsoft Wireless Optical Notebook Mouse...
MS WNOM 4000
Make sure batteries are good and try
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Jul 26, 2008 | Microsoft Wireless Optical Notebook Mouse...
Microsoft wireless laser mouse 5000
Assign a keystroke to the mouse, in this instance I assigned 'p' for pan (as per the .pgp file short cuts etc) against the scroll wheel click.
Click the scroll wheel, 'p' comes up on the cad screen, right click to confirm then the pan icon appears, hold the left mouse button and drag at your leisure. Yet to find a fix for Inventor.
Not ideal, but better than nothing at presnt.
Jun 08, 2008 | Microsoft Wireless Laser Mouse 5000
MS Wireless notebook mouse 4000
I have already broken two of them. It seems that the receiver is very sensitive to hits. Probably a PCB issue. I disassembled the receiver and discovered that if I bend it a little it starts working but if I leave it stops.
Jan 16, 2008 | Microsoft Wireless Optical Notebook Mouse...
MS wireless notebook 4000 mouse functions
Check your products documentation. Anyway this buttons can be programmed using the Provided Software included in the CD. Hope this helps.
Sep 19, 2007 | Microsoft Wireless Optical Notebook Mouse...
Microsoft Wireless Optical Notebook Mouse 4000 Logo
806 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
