Question about Fellowes DM 1200 CT Shredder
The red and green light are on and the blades won't rotate
I have not used this shredder in over a month. I tried reaseating the shredder and turning it off and on. I also pushed the jam buster button.
3 Suggested Answers
fellowesrep
  • 102 Answers
SOURCE: Red Light on, but no jam
Your problem is probally with the safety interlock switch on your machine. On the PS-65c It is located on the right hand side of the unit. There will be a tab of plastic on the inside lip of the basket that goes into a slot on shredder head. If plastic piece is bent or broken machine will not operate. If it does not appear broken make sure when you put shredder head on that it fits flush all the way around on the basket. If none of this helps contact Fellowes Customer Service at 1-800-945-4545 and we will be glad to assist you further.
Posted on Mar 02, 2008
JayBlair
  • 328 Answers
SOURCE: Unjamed, but jammed light remains on and won't shred
Most likely the PC board has gone bad. It will cost over 100.00 from fellowes.
Posted on Jan 12, 2009
RED Light is on (left of the green light)
Reverse shredder and clean out as much paper shred as possible. Use some lube oil. Hairclipper oil and canola vegetable oil are good choices.
Aug 26, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
I have a staples SPL826X shredder and it won`t shredd, but it will go in reverse. can someone help me?
If you can disconnect the power to unit and check shredding blade alignments to see if there is a clog or if the blades are out of alignment and stuck. If there doesn't seem to be a problem with the blades make a visual inspection of the off/on/reverse switch.
Nov 28, 2014 | Staples SPL826X (CrossCut) Shredder
Red light and green light on but motor will not come on
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 13, 2013 | Fellowes PS60-2 Shredder
Shredder does not work
Hello there. I'm sorry to hear about your shredder I'm sure there is something we can do. The first thing we need to do is check to see that it even turns on. If there is a light that turns on while plugged in then we know that it is properly turning on. If the light is off then it must be an electrical problem, either with your socket or your shredder. I recommend trying a different socket.
BEFORE TRYING THIS STEP, MAKE SURE TO TURN OFF THE SHREDDER!
If it turns on correctly you might want to see that the blades aren't stuck with paper. TURN OFF the shredder and try and move the blades with a screwdriver or a flat head. You can also see the paper in some printers. If you cannot see the blades then we can take an alternative.
You can find shredder oil in any office supply retail store. You put some oil on the blades and it lubricates them, and at the same time eats away the paper that is stuck. Most times this is the problem. If you can't go to the store you can use a little bit of cooking oil. That will do the trick as well.
If none of these methods work than it must be an electrical problem in the shredder. Hopefully not however.
Good luck
- Oblivior72
Mar 01, 2011 | Aurora Electronics AS662C Shredder
Shredder only operates in reverse
Check and try cleaning the "eyes" in the paper throat... if that dosn't fix it it could be the pcb inside...call Royal at 1-800-524-0799 for parts help.
Feb 17, 2010 | Royal CIA 12X Shredder
I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
Sep 01, 2009 | Royal Office Equipment & Supplies
Sep 06, 2008 | Fellowes Powershred 480 Shredder
Shredder won't grab paper
there has to be something in the path.
once you put the paper in it triggers a sensor that rotates the blades and grabs the paper there is nothing else in between the entrance and the blades. get a flash light and lok in to see what is blocking the path.
unless there are some paper in between the teeth /blades, that need to be cleaned out.
Sep 05, 2008 | Fellowes PS60C-2 Shredder
HR Specialist
try saturating left over paper with shredder oil and let sit for 4-5 hours or more this should soften paper enough to remove easier although it may be a little messy
Dec 27, 2007 | Office Equipment & Supplies
Fellowes DM 1200 CT Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
