Question about Addonics (AEFDDU2) External Floppy Drive
Driver AEFDDU2 model Addonics external card reader not seen by Windows 7
Card reader: unknown device in windows xp
You need to find compatible drivers for this device.
Drivers for your card reader can be found at LinkWorld's driver download page here:
http://www.linkworld.com.tw/ugC_Down.asp?hidDownCatID=4
It should be one of the first three device drivers. I can't quite determine which because the case specifications do no specify which model of card reader that particular case uses.
I hope this information has been helpful.
May 25, 2011 | Linkworld Electronic Co. Linkworld Black...
In my win 7 card reader doesnt support .. Why?
Try installing the device using Vista drivers, You need to use compactibility mode to get it to work though or :
1) Disconnected Media Card Reader and reconnected it. I wanted Windows to automatically detect the hardware change. Details of the first step:
a) Turned off Windows.
b) Disconnected Media Card Reader.
c) Turned on Windows.
d) Turned off Windows.
e) Connected Media Card Reader.
f) Turned on Windows.
2) Disabled and re-enabled the controllers.
a) Opened Device Manager.
b) Expanded IDE ATA/ATAPI controllers.
c) Uninstalled each item one by one.
d) Restarted the computer.
3) After the computer started, Windows reinstalled all the controllers
Jan 20, 2011 | Dynex External USB 2.0 Multiformat Memory...
Multimedia card slot not working
If the card slot is not working the fault is either the driver being missing or the card reader is damaged .. If you know it works ... just go to the support site and download the driver for it and install it ..
If the card reader was not a standard on this desktop , there is a possibility the driver is not on the hp site.. and you have to see what model is the card reader and what make and go to their support site ... (the card reader's manufacturer site )
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3254035#N152
If it seams that it has no driver fr the card reader i suggest to install the driver for the chip set .. maybe the card reader is not see cause it does not have all drivers for buses..
another way to install teh driver is to go to device manager by click right on computer folder ..and in there select properties / hardware /device manager ..
In the list look to see the card reader .. if it isn't present click right on computer in the list ..and select scan for hardware changes..
It will scan and show all devices connected and with no driver..
If you are running windows 7 or vista you can try to select the reader when it appears in the list ..click right on ir and select update driver ..and let the windows look for a driver on line .. or select one in the list ..But the best will be to locate the exact driver and install it .
Also if all seam OK but the reader still would not work open it and check the connections on the board.. This card reader is plugged on a usb port in the board .. and it may have an issue with the connecter ..Or try to install the usb 2.0 driver cause if this is a 2.0 usb device ..it may be not seen by the windows without this driver ..
Sep 26, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
My laptop VGNNW226Fb doesnt detect the sd card ..what to do? it is windows 7.
http://support.acer-euro.com/drivers/notebook/as_5510.html
select the card reader driver on the windows Vista line ..and download ..extract and install ..in 80 cases from 100 the driver fits for windows7 ..its the only way cause it is missing the driver thats the problem ...if it wont work ...you will have to get a cheap external usb reader for the sd card ..to use in the computer ..cause they do not have drivers in this model for windows 7 yet ..
Jun 15, 2010 | Acer Aspire 5610-4648 Notebook
Windows 7 doesn't read my Dynex usb 2.0 card reader
1. You have to see if the program is compatible with the Windows 7 operating system.
this is possibly due to drivers that the Windows 7 doesn't have in the "cab" files.
this manufacturer of the Dynex is your next step for a Windows 7 driver set.
May 29, 2010 | Dynex External USB 2.0 Multiformat Memory...
Memory Card
Do you have the driver utility cd for your card? try installing the driver from that even if it is not a windows 7 driver. You can always get an external card reader with usb interface if all fails.
Sep 02, 2009 | SanDisk 4GB microSDHC Memory Card
Photos wont import
Rip out to old drivers and reboot, then reinstall new ones, reboot again and retry.
To rip out:
1. Plug in Dynex device
2. Rt Click My Computer, manage, Devices.
3. Locate your Dynex device on Left side
4. Click to hilite and hit DEL key
5. Ans Yes
6. Shut down
7. Pull Dynex device
8. Restart
9. Goto site http://www.dynexproducts.com/t-drivers.aspx and DL new drivers
10. Unzip and Install new drivers (Pay attention where yhey go to)
11. Shutdown
12 Restart
13. Try Dynex again
If it STILL won't work, reinstall the last Windows service pack. and reboot and retry
Dec 31, 2008 | Dynex External USB 2.0 Multiformat Memory...
Addonics web cam can install w/o the driver or installer
install addonics pocket PC camera software by line
Sep 06, 2008 | Computers & Internet
Addonics (AEFDDU2) External Floppy Drive Logo
37 people viewed this question
Top Addonics Computers & Internet Experts
David Payne
David Payne
Are you an Addonics Computer and Internet Expert? Answer questions, earn points and help others
