Question about Brother Sewing Machines
Brother sewing machine ce-5500prw /the reverse does not work
The reverse button does not work/why
RickE1
  • 202 Answers
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Posted on Nov 25, 2007
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
  • 152 Answers
SOURCE: Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Posted on Oct 07, 2009
  • 96 Answers
SOURCE: brother sewing machine sews in reverse only
you will need to have it serviced sounds like an internal issue with the dial
Posted on Dec 13, 2009
kbjkadkins
SOURCE: Machine sews only in reverse
My kenmore 12 stitch was stuck in reverse. My friend used to work with a repair man, she said to open bottom some times thread is bound up, and may need oiled. My husband checked and found a bunch of lint and dust, he removed it and oiled it. My machine now works like new. Also sometimes the spring that operates reverse button can break or come loose. Good Luck!
Posted on Dec 06, 2012
Where can I find this board model#XE 7316001 for a brother CE 1100PRW computerized sewing machine?
somewhere like this or direct from Brother
http://www.brother-usa.com/homesewing/
Brother - Machine Accessories (feet, needles,globes,spare parts ...
www.sewingmachinewarehouse.com.au/machine...needlesglobesspare-parts/brother/
  1. Cached
  2. Similar
Sewing Machine Warehouse are authorised dealers for Pfaff, Singer, Brother, ... Parts and Accessories to suit Brother Machines. ... 7mm- For machines with a 7mm stitch width (feed teeth are set wider) ... Brother Open Toe Free Motion Foot. Missing: ce ‎1100prw
Brother Sewing Machine Parts & Brother Serger Parts
www.sewingpartsonline.com/brother-sewing-machine-parts-model-list.aspx
  1. Cached
  2. Similar
We have a very large selection of genuine and replacement Brother Sewing Machine & Serger parts available. If you can't find the Brother Part(s) you are ... Missing: 1100prw
Brother Sewing Machine Parts ' eBay
www.ebay.com/bhp/brother-sewing-machine-parts
  1. Cached
  2. Similar
Find great deals on eBay for Brother Sewing Machine Parts in Machine Parts and Attachments for Sewing. Shop with confidence. Missing: 1100prw
Sewing Machine Parts warehouse all Singer Brother Janome Pfaff ...
www.sewingmachinesales.co.uk/sewingmachineparts/
  1. Cached
  2. Similar
Suppliers of sewing machine parts attachments and accessories for Singer Brother Janome Paff, Toyota and Husqvarna sewing machines or overlocker spares. Missing: ce ‎1100prw
Sewing Machine Accessories & Spares ' Janome, Brother, Elna, Pfaff ...
https://www.gursewingmachines.com/sewing-spares-accessories
  1. Cached
Sewing Spares & Accessories: UK's biggest dealer of Sewing Machine Parts, Needles, Sewing Foot and all ... CE 5500, 8080. ... At GUR we have sewing feet for Brother machines and all styles of sewing, have a look at our invisible and ... Missing: 1100prw http://www.brother-usa.com/homesewing
Nov 20, 2016 | Brother Sewing Machines
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
My brother ce8080prw machine will not stitch in reverse and is stuck in abasting stitch. how do I reset?
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Nov 04, 2012 | Brother SE-270D Computerized Sewing...
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
I have my Mother's Brother XL3750, no book or accessories. It will sew in reverse only. I don't even know where the reverse button is. The only thing that I have tried is the big lever front...
you can download a manual for your machine from the Brother website,
link is
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000452/bm2736xl26i35i375ug04enes.pdf
Reverse is the big lever in front but it should be sprung so you need to hold it down to reverse; if your machine is only sewing backwards, this lever might be stuck or locked into position. Check out page 25 and 26 in the manual for specific info.
Sep 10, 2011 | Brother XL3750 Mechanical Sewing Machine
The push down button for reverse is stuck and will not reverse. How can I fix this?
Just buy a replacement push button from Brother
Sewing Machine dealer.
Nov 08, 2009 | Brother LS2020 Sewing Machine
I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Jul 02, 2009 | Brother XR-65t Mechanical Sewing Machine
Brother CS-8060
if you are looking at your machine there is a trio of "buttons" it the one on the right looks like an upside down u with an arrow pointing down on the right side... press that for reverse...
Aug 21, 2008 | Brother CS-8060 Computerized Sewing...
Sewing Machines Logo
26 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
