Question about Pool & Spa
Triton t90 power going to it and won't go - Pool & Spa
  • 1,631 Answers
How do you know this? Is it "Proper" amount of power? Check with multimeter.
Posted on Jan 29, 2014
Hi I got a plumber to replace a triton T90 si with a new z model it only has half the power of originalIDo you know why the problem could be?
You might want to compare the FLOW RATE of the old model with the flow rate of the z model. It seems that in order to "save water" the manufacturers are decreasing flow rates to save the planet...or to meet new regulations.
Good Luck.
Feb 12, 2015 | Home
How do I reset the lamp timer to '0' hours when I replace the bulb?
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go.
Mar 18, 2014 | Toshiba TDP-T90 Multimedia Projector
I have a triton t90 shower it was workin grand until 2day when i was fillin my daughter paddling pool wit the tap in the garden that is connected to the hot water and it must of empty the tank as there was...
As per my view, you should immediately contact to a professional who can fix this shower problem very easily and quickly. You can also explore latest shower enclosures that are available at reasonable price.
May 26, 2012 | Home
Drip from shower head triton t90 when turned off
The shut off is not closing completely remove the handle and faucet assembly and take it to the hardware store to purchase the right washer, o-ring, or gasket. If there are two take them both so you don't have to do this again for the other side.
May 08, 2012 | Home
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
When I power up all I get is the Magellan Triton screen. My pc does not recognise the device also
1.Ok, if you have tried the manual update and it won't work then the thing to do is download this file:
http://www.lenwoodcc.org/triton/t500tfat2.zip
To download the file just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
2.And then connect your GPS your computer and start it in the developers mode - which should make it connect to your computer as a USB driver.
To start your GPS in developer mode ,simultaneously press and hold the POWER - LIGHT - UP ARROW buttons as you start the GPS.
Want to get out of this mode, you can reboot the unit by simultaneously pressing and holding the POWER - SELECT - ESC buttons or just take out one of the batteries.
3.Next unzip the T500TFAT2.ZIP file to a directory on your hard drive. Once you have that unzipped go to "My Computer" and access the TFAT directory on your Triton and erase all of the files on it. Then copy all of the files from the T500TFAT2 file that I sent you. Once you have the new files in place then disconnect your Triton from the computer and reboot it and see if it works.
If you need further assistance please feel free to contact me.
Feb 07, 2012 | Magellan Triton 400 Handheld GPS Receiver
Toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
Toshiba TDP-T90 projector - Won't turn on
the power supply capacitors are dried up. replace the power supply.
Jul 29, 2009 | Toshiba TDP-T90 Multimedia Projector
Usb connect-it problems.
Do you power off before you connect all attachment
Dec 13, 2008 | Epson TM T90 Printer
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
