Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Shows rinse cycle and will not go to other setting
Will not change program
  • Fisher and P... Master
  • 3,247 Answers
The controller is not sensing the top panel. Clean the pads with clean damp cloth. If no change, then turn off the mains power and back on.
see if you can change the settings.
Posted on Jan 19, 2014
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
What should i do? It continues to add time and cycles?
just press the botton of each cycle want u want,like add rinse press rinse botton and it will add rinse,press spin botton it will add spin,but for washing,cant coz already set the time,default program for wash and cannot change
Oct 31, 2013 | Samsung WA50F9A8DSP Platinum 5.0 cu. ft....
Programming
Your dishwasher drawer appears to have got stuck in some sort of a diagnostic mode. The 3 lights are a code telling which diagnostic it is in.
I am assuming you have turned off and on at the mains power and it makes no difference.
I need to check a few things with you first, but I am assuming the controller is not looking good. The easiest way to confirm this is take the controller from the top one and try it below. But you need to feel comfortable doing it.
Let me know if you want to call a technician or do it yourself.
Jun 20, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Maytag commercial front load washer MAF18MC3AS has 3 rinse cycles. can this be changed to 2 rinse
No. unfortunately, this is a preset situation. this is programmed into the main logic sector on the control. It is preset during manufacturing, and cannot be changed.
Nov 13, 2009 | Washing Machines
I get error F1 every time I start and before the rinse cycle. I will change cycles, change settings within cycle menus, it tales at least three attempts of shutting it off and restarting it. Now it will...
here's the part # W10189966. I guess whirlpool had a recall on the units and revised the control boards. might want to call whirlpool on that. Good luck :)
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
No rinse cycle
If it is new, would you not call Hobart for a warranty call? 1-800-444-4764 to reach the nearest branch in Canada.
Seeing it's new it is most probably not programmed correctly. On the control board is factory jumper J5, short thse two pins and press ON on keyboard. when the display shows ty remove short. pressing select on the CB will change the options, pressing up arrow will incriment the change options. first setting is machine type= AS,second is id, hot/cold or plain AM15 only, select H,C,or P.
3rd is tc,auto temp control. The rest will not affect your condition. Press OFF on keyboard to save and exit.
Jul 03, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
My Hotpoint Ultima WT960 is in the middle of a program and on the rinse cycle and on the screen is flashing H2O the door is locked with my wool wash inside. What do I do.
Check the program that you have it set on for the wool cycle. Some washers have where you can "add water" in the rinse cycle. If yours has this feature, I would try that also.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
53 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
