Question about Cerwin Vega V-10S Subwoofer
Cerwin Vega V-10S Subwoofer doesn´t sounds good
When I first installed and connected my Cerwin Vega Subwoofer in to my DENON AVR-485 the Bass sound was mega-awesome!!! but a month later the the Subwoofer starts to make a rare noise and the bass tones didn´t work good, its like a vibrating sound, like if the cone is broken, I already check up the connections, the subwoofer (horn) cone is fine and everything seems to be ok. What is the problem? Thanks... RAUL
  • 71 Answers
Dear "rai17"
This, to me, is most likely the voice coil inside the driver rubbung against the yolk plate, or possibly the spyder slapping the metal plate underneath it, or the amp-(if it has one?) getting tired. this can occur from poor build quality, or playing the subwoofer too loud. depending on how much it cost you, you may want to get it repaired(voice coil re-alignment or something or new amp). But the way it seems, it is probably the driver itself. subwoofers get looser as they break in. This one may have been over-broken....sorry
I hope this helped clarify what is happening!
Posted on Jun 09, 2009
SOURCE:
Bad plate amp
http://www.parts-express.com/cat/subwoofer-plate-amplifiers/332 Subwoofer Plate Amplifiers
Feb 18, 2014 | Cerwin Vega LW12 Subwoofer
Blown up denon avr 3801
FIXYA can not do anything for you .
Nov 15, 2017 | Denon AVR-3801 Receiver
Hello. My ve 28s crackles when in standby mode, and also plays crackly bass. Please help me by telling me which component to replace within the amp. as I have no Cerwin Vega agent support here in South...
This "Crackling" Problem is common with the Cerwin Vega VE-28S Subwoofer. If your subwoofer is out of warranty, and you know how to solder, you can fix the problem by replacing a few resistors, and transistors inside the amplifier. Get the parts on ebay: http://cgi.ebay.com/250756306868/
Sep 09, 2010 | Cerwin Vega VE-28S Subwoofer
Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
What size box do i need for a cerwin vega v124 and ported or sealed
Hi there, If can you give me an average dimension of your trunk your installing it in. And Ported - Sealed is really based on what you are trying to achieve in the vehicle. Ported in my opinion sounds better in cars with an enclosed trunk where as a sealed subwoofer plays better in a hatchback vehicle where the car itself acts as a second box.
Nov 15, 2009 | Cerwin Vega 124 Car Subwoofer
I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
What enclosure do i need for cerwin vega v-max 124 12" sub
Just get a 12" sub box enclosure for an audio store near you or make a custom box, a larger box supposedly gives you more bass yet at the cost of boot space. I have a type R sub and the box is only as big as it needs to be for the sub to fit and it gives amazing bass.
Aug 04, 2009 | Cerwin Vega V-Max 12 Car Subwoofer
Cerwin vega ve-28s
I have the same problem and was told that it is failed amplifier....
Dec 02, 2007 | Cerwin Vega VE-28S Subwoofer
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Cerwin Vega V-10S Subwoofer Logo
588 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Ben Armstrong
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
