Question about GE Refrigerator Freezer Gasket - WR24X10063
Gasket installation How to install door gasket
  • 3 Answers
I tried to re-initialize the freezer by unplugging it for a few seconds, then re-plugging it and turning the freezer back on, but, unfortunately, to no avail. NOT A SOLUTION EITHER, BUT AT'S A TRY.
Posted on Nov 22, 2013
Testimonial: "What has this got to do with installing a new door gasket?"
How do i install a new door gasket/seal on my Frigidaire upright freezer model # LFFH21F7HWA ?
Good Morning Friend,
I understand you want to know how to install a new door gasket on your Frigidaire freezer, model# LFFH21F7HWA. Typically this is not a do it yourself repair, as there are no step by step instruction manuals that will tell you how to do this. I suggest either contacting the manufacturer or your local authorized technician for further assistance. The technician has been trained on your specific appliance, and should be able to replace the new gasket with ease. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire 20.3 cu. ft. Upright Freezer...
How difficult is it to replace a Door Gasket - True TS-49F Freezer
The old gasket just pulls directly out from its slot in the door. Start about 3" away from a corner, then pull the corner out; the rest is easy. Soak the new gasket in warm water before fitting; it softens the edge and makes it easier to push in.
Apr 23, 2014 | True TS-49F Stainless Steel Freezer 2...
Ice forming on "ceiling" of freezer, on hinge side.
Yes it is and its typically quite easy to do.
First you will need to determine what type of gasket is in the unit. Typically its just a push in style gasket that is held in place by a dart style backing that holds it into place.
A tip to use is to soak the new gasket in screaming hot water for about 5 minutes before installation. The install it right away. The hot water will make the gasket easier to handle and it will slide into place easily. The just leave the door closed for about an hour to allow the new gasket to form up and hold into place.
Good luck
May 19, 2010 | Electrolux 16.8 cu. ft. Upright Freezer...
How do I change the door seal on a gibson UR freezer?
The most important thing is to make sure the new seal is warmed up to room temperature so it is soft and workable. Since the seal on mine is attached to the top door there is nothing to gain by leaving the door attached. Working upside down would leave the door open longer than just taking it off.
If you still have food in the freezer just put blankets over the top until the door is back on. If you have screws holding the seal it will go much easier. Mine has plastic pins that break easily pulling them out.
Get the edges as straight as possible to avoid leaks.
Sep 19, 2009 | Freezers
Mu upright freezer door seal was loose and it is leaking from door would this cause domw food to thaw and can it be fixed
a leaking gasket can cause food to thaw and it can be fixed if a new gasket is avaliable from local appliance parts place..the gasket is held on by the liner which is removed by gently lifting the gasket and removing the screws..the reverse to install the new gasket
Sep 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer Door
Defrost to get rid of icicles (temporarily). shut the door on a piece of paper , and try to pull it out . The gasket should be tight enough with the door closed that the paper will resist being pulled out, or not come out at all. Check all around the door, it might be bad in just a small area. A bad gasket means warm air enters, cold are exits, and where the two meet, condensation forms, which inside become stalagtites (I mean icicles). The service guy should have checked it, but hey, who would expect a new appliance not to work properly? If the gasket checks out ok, maybe insulation was not installed properly in the door, which would cause temp variation. countrycurt0
Aug 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
GE Refrigerator Freezer Gasket - WR24X10063 Logo
55 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
