Question about GE Stove/Oven/RanSurface Burner Knob - WB03T10025
No power to buner receptacles on hot suface G.E. stove
No power to ransurface buner knobs
    Sergeant:
  • 446 Answers
You can check circuit breaker and if that is not it you may have a bad burner switch
Posted on Nov 23, 2013
Ge wiring schematic
theres usually a schematic on the unit somewhere that will help you
Aug 19, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
GE gas stove ....control panel has no power to turn oven on but oven does have light....do i need to replace control panel
I try to clean it up a thin tool pen and then put the fan on it and then try Does it work
In the case did not solve the problem, change the panel
Oct 09, 2013 | GE Stove/Oven/RanSurface Burner Knob -...
Show me how to install a part for my frigidaire stove top the switch has change
Sharon,
Pull out stove from the wall,
Unplug stove. Now you are safe!
With a phillips screwdriver, remove the backpanel.
The switch you are replacing, remove knob.
Remove the two screws that hold the switch in place.
When switch is free, remove one wire at a time, and make sure you put them on the new switch as you remove from old.
Fasten switch in place, close up the machine. plug it in
Enjoy your new buner
bweazer
Oct 16, 2010 | Frigidaire FEF366 Electric Kitchen Range
There is a red light visable thru the glass top on the left rear of the cooktop. cannot find this light anywhere in the book. it is on and has never come on befor
Yeh,
I ve seen this before.
Try turning on one buner at a time. Make the element red hot!. If one does not get red hot. make a note of that switch.
Some stoves create a way for a technician to know which switch is shorted and uaually it is the one that doesn't get red hot.
If all buners are red hot , preheat oven for 350 and wait. it should take 5min to heat up oven. if oven not hot ,one of the elements is blown
Aug 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Whirlpool electric range burner exploded ''on'' light on always
Hi There,
While the stove is unplugged remove the bad burner from the stove and set the bad burner's control knob to the "OFF" position. Now plug the stove back in. If there is a problem it should trigger the breaker and shut off the stove. If you are not comfortable doing this you might want to ask someone.
The explosion was due to a shorted burner element and once it is removed there shouldn't be any more problems. I hope this was helpful and I hope you get your stove going again.
Mar 26, 2009 | Kitchen Ranges
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Burners - Oven not working
There is a problem with the 220v power to the stove. Indications are the neutral connection is missing either at the stove, in the plug receptacle or in the breaker panel.
Feb 24, 2007 | Maytag Admiral LER3330AAW / LER3330AAZ /...
GE Stove/Oven/RanSurface Burner Knob - WB03T10025 Logo
57 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
