Question about VinoTemp VT24-G 24 Bottle Wine Cooler
My Vinotemp TC32G thermostat will not lower. It keeps jumping to the highest temperature control
2 Suggested Answers
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
Where can i order of P6R8MC OR0503 relay?
http://www.appliancepartspros.com/mcf-ptc-starter-312200500017-ap5671689.html
Aug 26, 2016 | VinoTemp VT-TC32G
My vt-tc32g will work for a bit and then stop
If it cycles very irraticly then the temp control could be out of calibration and will need to be replaced. There usually is about a 5-10 degree difference between on and off for the temp control and will be worse with no product in the cooler
Sep 06, 2012 | VinoTemp VT-TC32G
Lower zone will not cool. 45 bottle model.
This is a VT-45 (not a TC32 as mentioned), right? If its just the lower zone that isn't cooling, it could be a few things that are happening. Most likely the fan isn't working or there is a sensor issue monitoring temperature for the lower zone. I'd recommend having a service person diagnose to be sure. Otherwise, have you contacted the manufacturer, Vinotemp, for help as of yet?
Oct 02, 2010 | VinoTemp (TC32GB)
Do you carry the thermostat for vinotemp wine cellar TC32G?
You can purchase replacement parts for virtually all Vinotemp coolers directly from Vinotemp. Some parts are listed/available on Vinotemp.com (http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts) But otherwise, just give their service department a call or shoot them an email and you can confirm the part number and purchase the required part.
Jul 23, 2010 | VinoTemp (TC32GB)
Tc32g unit gets too cold
Too cold usually means temp control switch is out. Temp controller turns the compressor on and off based on the temp. It can be a mechanical switch or a circuit board, but good chance it has failed.
Mar 29, 2010 | VinoTemp VT-TC32G
I have Vinotemp wine chiller model number VT-21TEDS-2Z. It is Dual zone and the bottom zone temperature is to low. I set it to 60 but it is at 49. The temperature controller does not seem to control it.
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Nov 07, 2009 | VinoTemp (VINO-24GN)
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
My vinotemp will not stop when it gets to 55 degrees - it keeps running and starts beeping when it gets into the 40's - it is a 2 door 500 bottle model
Check the coils to ensure they are free of dust(can be vacuumed) and the doors on the unit are sealed properly. Sounds like there is a thermostat problem. You can get these parts from Vinotemp @ 800-777-8466
Jul 15, 2009 | VinoTemp Refrigerators
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Aug 29, 2008 | VinoTemp (VT60GNV) Wine Cooler
Furniture Logo
71 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
