Question about Konus Microscopes Biorex Biological Microscope w/ Infinity-1 System
The diaphragm on the Konus microscope will only show the smallest view-like a pinpoint, even after I adjust the diaphragm so that it is supposed to provide a larger view with more light.
2 Suggested Answers
  • 43 Answers
SOURCE: how do i connect a digital eye piece to my konus
You can use a Ken-A-Vision Pupil camera and slide it over the eyepiece or if you remove the eyepieces Meiji Techno has a large selection of adapters that will work with most camera's, that will fit in inside diameter of this eyepiece.
Posted on Dec 30, 2010
Is there a "C.D." so I can use my 5829 gamera on Micosoft 7 computer?
This looks like a Konus microscope. It normally works with Windows Vista.
Not sure how well it is supported. But if you go to Konus website and ask a question you may get an answer. The company is based in Italy.
You may need special drivers for it.
CONTATTI
Aug 15, 2014 | Konus Science & Laboratory
Hello, i need the software for the Konus Pix-4 Digital Microscope 100x 200x 300x / VGC.It is very difficult get it.Please help!!!MZ
If it is the same software as provided for a 100x200x450, it is distributed by ArcSoft. Maybe check: https://pulaskicotech.wordpress.com/tag/arcsoft/
Nov 18, 2013 | Konus 5023 model Konuspix 450x Digital USB...
Windage and elevation adjustment won't move on konus 275 scope
you may have run out of clicks or the adjustment internals are damaged
Nov 02, 2013 | Konuspro 275 Muzzleloading Riflescope...
What is the other types of microscope ? how do they differ from a compound microscope ?
Compound Microscope
  • Compound microscopes can be found in most biology and science classrooms. They are electrically operated and use light to enhance the image of a cell. They will have multiple lenses for viewing.
Dissecting Microscope
  • Dissecting microscopes are also known as stereo microscopes. They have low magnification and are also light powered. These microscopes can view objects larger than what a compound microscope is able to handle, in three dimensions.
SEM
  • A Scanning Electron Microscope uses electrons instead of light to create an image. These microscopes produce three-dimensional images with high resolution and magnification. They also have a larger depth of focus.
TEM
  • Transmission Electron Microscopes use electrons instead of light to create an image. The material prepared must be very thin. The beams of electrons that pass through it give the viewer high magnification and resolution. These give two-dimensional images.
Jul 03, 2011 | Computers & Internet
I have a new-in-box Konus Motormax 130mm 1796 I got about 3 years ago (it was described as a spotting scope) from a supposed Konus dealer on ebay. He then sold me a $100 Celestron tripod for it claiming...
Contact a regular DEALER for this scope and see if they have one. You may just have to look in a well stocked hardware store for something you can use to mount the scope on the tripod.
Feb 05, 2011 | Konusmotor 1796 (200 x 130mm) Telescope
How do i connect a digital eye piece to my konus opal 5418 microscope?
Dec 28, 2010 | Konus OPAL 20x Binocular Microscope
I'm using the Nikon ECLIPSE e800 microscope and for some reason there is a shadow on half of my slide. Also, I can usually find and take pictures of slides with the lamp adjusted at about 5 or so but...
There are a few things that could cause a shadow in the field of view. First if the condenser is not centered, this can create a crescent shaped shadow and rob your image of light. Center the condenser and raise it to within about a 16th of an inch from the top of the stage.
Second, the slider on the head which diverts light from the eyepieces to the camera must be fully engaged to the "camera" position
Third, make sure that the diaphragm on the condenser is not closed too far. There is an adjustment ring for this. Set it to 70-80% of the numerical aperture of the objective you are using.
Fourth: if there is a "swing out" condenser lens you will need it completely in or out depending on the objective you are using. for 2x-5x you need the swing out condenser lens completely out of the light path. For objectives 10x and up you need the swing out condenser lens completely in and centered in the light path.
If these things are properly adjusted you should not have a shadow in the field of view. If you still have a problem, let me know.
Dec 17, 2010 | Nikon Science & Laboratory
Microscopy; Relatively large spots on unknown surface obstructing view
HELLO..
There is five part in microscope
1. Eye piece
2. Binocular tube
3.Objective
4. magnification changer or joom accembaley
5. illumination segment
Try to make it out which part is gives a effect to your vision.
as per my suggesition illumination asembely you just clean it first.
keep in touch
regards
INDRAVIJAY
Dec 30, 2007 | Tasco 750 Monocular Microscope
Konus Microscopes Biorex Biological Microscope w/ Infinity-1 System Logo
Top Konus Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Konus Science and Laboratory Expert? Answer questions, earn points and help others
