Question about Xerox WorkCentre 7120/P Printer
My 7120 has gone all wierd, it said error 10-328 I put in a new fuser it ran one copy and then said 10-338 and all of a sudden it won't scan email contacts are gone it it apperas info was wiped clean any idea ?
4 Suggested Answers
  • 20 Answers
SOURCE: xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
Posted on May 12, 2009
SOURCE: i have error code h 3
this problem can be cause by three things abadheat lamp/thermalfuse/thirmister make sure the sensor is clean first the thermal fuse is self resetting when it cools down.
Posted on Jun 03, 2009
SOURCE: Xerox 3535 error 010-348
dc 3535 error code 010348
Posted on Dec 10, 2010
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
How to reset c2557
i put in a brand new developer unit, using the new developer I had just replaced into the old developer unit, reset drum and maintenance counters, ran F8 again. The machine came into ready, ran (1) copy, jamed on fuser entry and C2557 fired again. I then reset the switch in the back (right hand side), reset the switch on the main board, reset drum and maintenance counters, ran F8 again. The machine came into ready, ran (1) copy, jamed on fuser entry and C2557 fired again.
Aug 13, 2014 | Office Equipment & Supplies
Inside yellow
please i need how activation code xeror 7120 workcente
Jan 14, 2014 | Xerox WORKCENTER 6505DN COLOR LASER MFP,...
2005 Kia Optima won't run, CodePO338?
error code PO 342 was on the low input. Now the code you are getting is on the problems on the high output for the same Camshaft position sensor. Something "now" is putting out too much juice and can only assume it has to be in the ICM (ignition module) or the coil. If not qualified to do the readings yourself, you will have to take it to someone who can do it.
Sep 01, 2012 | Kia Optima Cars & Trucks
ERROR SERVICE 49.FF95 IS COMMING
ust had one here do the same - it came in with a blown out fuser sleeve where the ends shredded as the heater strip's slick surface went dull (coating wore off on the ground end, caused to to stop while the rest of the sleeve turned and twisted the snot out of it) so I never ran it before I rebuilt the fuser and this is a rare one where the heater has to be replaced. Inserted the rebuilt fuser, got the 49.FF95 error - looked it up and most tended to refer to doing a cold reset or replacing the formatter if that didnt get it. Tried the cold reset, nada. Ran an engine test, ran ok but still the error. Reseated the memory dimm - nada. Swapped position of the boot select jumper on the formatter - nada and swapped back with no change. Hmmm this is BS! Started wondering if my rebuild had something to do with it so I installed a temp RM1-1082 fuser and had the error also so time to focus on formatter (with the embedded POS Jetdirect). Read the above comments referring to the Jetdirect possibly being a cause but it's not connected, it's stand alone. Ok next comment says turn off the internal LAN - BINGO! Error gone. It's the embedded crappy Jetdirect. So I ran some prints, all fine. Re-enabled the internal LAN - error is back. Verified Jetdirect failure. Ok so I go bac to diabled, download the 08.015.0A firmware and send it via copy/b on a parallel. Firmware went through properly and took. Re-enabled internal LAN - still get the 49 error. Must be that the internal LAN is AFU. Turned it back off and inserted an EIO Jetdirect and all is well.
Mar 30, 2010 | HP LaserJet 2420dn Printer
Copying only half copies
Sounds like the charge corona wire may be out of place, or the scortron grid is shorting. It is NOT the HV unit.
Jun 16, 2009 | Minolta EP1083 CS/PRO Copier
Fatal Error Code 173 - OKI 5100 copier
173 is a fuser upper roller low heat error.
Nov 19, 2008 | Office Equipment & Supplies
E0 message
It has a fuser error, needs new fuser, will not just reset when error is present.
The fuser is the hot bit that the paer goes threw to bond the image on the paper, yours has a blown heat lamp or a faulty temp sensor (thermister)
This area is not for playing in cause it is a electrical and fire hazard, just have new fuser fitted and error will be gone.
Oct 28, 2007 | Canon PC-921 Black and White Copier
Xerox WorkCentre 7120/P Printer Logo
108 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
