Question about Microsoft Xbox 360 Console
Error 68 on xbox
When I turn on my Xbox an error 68 shows
    Novelist:
  • 112 Answers
I contacted Microsoft explaining your issue and they replied saying that error 68 means that there is a hard drive failure. You will have to send your xbox in, but if you are under warranty you won't have any problems. Also something you can try is take your hard drive off and see if it will play.
The failure is not always as big as you think, it can be fixed at home.
If you don't want to send it away or it's not under warranty anymore you can try the following.
1: If you have a computer with sata cables.
Remove your hard drive and plug it into an extra sata cable and boot your computer just to see if the damage is serious. It will display in your My Computer. If it does not display in your My Computer go to Start type 'Computer Manager' go to storage > Disk Managment
if the damage is repairable your Hard Drive will be Displayed there but then it will be 'Offline' or a 'Dynamic Disk'.
If OFFLINE click left and select ONLINE.
If DYNAMIC click left and select CONVERT TO BASIC.
Now you can re-insert into your console.
2: You can also remove it and tap it very lightly against a surface(sometimes the disk just get stuck).
If you still stuck email me at markusmaritz333@gmail.com
and i will guide you step by step with other solutions.
Good Luck!!
Please rate me.
Posted on Nov 22, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: Corrupted profile on XBox 360
I have heared that if you just delete the profile, just the profile, everything will be just fine (note: This only works if your profile is on xbox live).
Just go to memor, then go into the saving device the corrupted profile is on. Then "click" on the botton that says profile and delete the corrupted profile. Remember; the profile will be a small save and not taking up most of your harddrive, look for something with MB size, not GB size. When you have done this, go to "recover gamertag" and do so for the profile you just deleted. After all this, your game saves and achivements should be present and working.
Posted on May 03, 2009
FixMyConsole
  • 174 Answers
SOURCE: One red light - Error: E 68 - Problem code 0110
Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
We offer a repair service.
FixMyConsole
Posted on Jun 03, 2009
mattrubin
  • 161 Answers
SOURCE: E 68 error....will transfer cable help fix it?
The E68 is a weird error. Its normally from a hard drive failure. The underground xbox 360 scene says
THe E68 is a Hard Drive Error. The Hard drive is not properly configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
If the xbox can play without the hard drive then this error can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices.
If its the hard drive or your console causing the problems contact Microsoft they will probably fix your hard drive and maybe recover your game saves. On the newest games that info is stored on xbox live.
http://support.xbox.com/support/en/us/nxe/contactus.aspx
Posted on May 09, 2010
We have an error 68
Error 68 usually means that there is a hard drive failure.
  1. Try taking off the hard drive and starting the xbox.
  2. If the gray screen still comes up then it's a hardware failure in the xbox.
  3. You have 2 options, send it into microsoft or buy a new hard drive.
Feb 19, 2011 | Microsoft Xbox 360 Console
Error 68 came on my xbox after 3 attempts it started working will error 68 come up again?
The hard-drive in your Xbox may have some bad sectors. What were you doing when you received the error?
Apr 04, 2010 | Microsoft Xbox 360 Console
Error e 68 on xbox 360 game console
Take off your hard drive then try a game , if it plays the game then most probably you need to replace the hard drive.
Apr 02, 2010 | Microsoft Xbox 360 Console
1 Red Light, error E 68
E68 is an hard drive error, turn it off and remove your hard drive, try to play a game without it, if it works, turn it off again, replace the hard drive and see how you get on, if it still will not work can you try the hard drive on another xbox, this will tell you if its a problem with the hard drive or an internal problem with the box.
Vote if this helps.
Jan 26, 2010 | Microsoft Xbox 360 Console
FixMyConsole
Jun 03, 2009 | Microsoft Xbox 360 Console
Error 68
Hi!
Also visit this link--
Xbox Error 68
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Feb 19, 2009 | Microsoft Xbox 360 Console
I get error code e-68
there's a possible hard drive issue on this.
try the ff:
-turn off your xbox
-remove your hdd from the xbox
-turn on the xbox while the hdd is removed
-if you're still getting the sme error code, your xbox needs to be repaired/replaced
-=hope that your xbox is still under warranty=- ^^
Jan 19, 2009 | Microsoft Xbox 360 Console
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Aug 24, 2008 | Microsoft Xbox 360 Console
Xbox 360 error
if your xbox 360 has an error reading e68 the best solution is to take off the hard disk drive and insert a memory card
May 22, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
