How to login to Profitin60seconds
Have downloaded Profiyin60seconds but when I click on the icon it bypasses the login and therefore doesn't work
  • 4 more comments
  • Gary Rathmell
    Gary Rathmell Nov 23, 2013
    Yes I have tried reinstalling about 12 times without success and the creator states they do not offer technical service so I am stuck
  • Janis
    Janis Nov 23, 2013
    I don't think you even need such a program. What software were you looking for( For me to find an alternative)?
  • Gary Rathmell
    There are no alternatives to this software which is a stock market indicator program which has to be installed on another program which monitors the market
  • Gary Rathmell
    The other program is Tallinex Metatrader 4.
  • Janis
    Janis Nov 23, 2013
    If you need to see the stocks, you can use the Finance app on Windows 8, or Bing( online). Also, there are many alternatives. Or really aren't there?
  • Gary Rathmell
    Gary Rathmell Nov 24, 2013
    Profitin60seconds is a software which tells you which way the graphs will go with an 80% rate of success, you can't get a service like that free anywhere.
  • 1,824 Answers
try re-installing it. If it doesn't work, then try contacting the creators.
Posted on Nov 22, 2013
How do I log in to Snapchat on Android?
When you tap the snapchat icon to go into snapchat, it should come up with a screen saying "login" or sign up" press login and then enter your details
Jun 08, 2015 | Android Apps
What drivers can use for my video and sound card? ESC P4VMM2
driver for motherboard ECS P4VMM2
On this page you are offered with driver for p4vmm2 motherboard existing in our database. Icons placed on the left of file name will prompt you in which format and in what language driver download ECS P4VMM2 motherboard are represented in this file.
If the needed file doesn't exist, therefore the desired driver is missed in our database. It can be ordered in the File Request section.
You can also try to find the appropriate driver for kindred motherboard ECS models by clicking on the links shown below.
  • http://www.fixdevice.com/drivers/motherboard/ecs/p4vmm2.html
  • http://www.driverstock.com/elitegroup-p4vmm2-driver-download/25-9-3830/index.html
Sep 20, 2011 | Computers & Internet
My laptop speaker is not working
Hi solomonowobu...
Right click on the speaker icon on your desktop and make sure the volume is up on your computer and not down in the muted position.
Left click on the speaker icon on your desktop:
A window opens and you will see two choices...select Volume control, when the window opens make sure none of the mutes are checked, if they are uncheck.
If this doesn't solve your problem you may have to download new audio drivers for your computer, and it that doesn't clear the problem, then you will need to send it to get repaired as it is a hardware problem.
Please take time to rate me
Sep 04, 2011 | Computers & Internet
How to uninstall deepfreeze if forgotten password?
What we are going to do is to load a new instance of Deep Freeze login program and we'll change it in such a way that it will accept any password as a valid one.
Let the Play Begin
The first thing to do is to find some data that we are going to use later to load our login program instance. For this, load the Process Explorer. Once it is loaded, we can see a list of all the processes our system is running, among them is the login program called FrzState.exe or FrzState2k.exe. You may expand the tree if required to find this program. Right click over the program's name and select "Properties". A new window will be opened with the process properties.
Under the Image tab, note the property named "Command Line". Note down the value of "Command Line" including the three numbers at the end of the property for future use in this tutorial.
Run Ollydbg.
Quote Note: Make sure that OllyScript is properly installed. Make sure that the menu "Plugins" and submenu "OllyScript" is available. If this menu doesn't appear in the program, that means the plugin is not installed properly. To install it, go to the menu "Options" and select "Appearance". In the "Plugin path" box write the address where you copied OllyScript files, press OK and restart the program.
On the 'File' menu select 'Open' and look for the login program file (remember that Process Explorer told you where it was). In the 'Arguments' box write the three numbers you've written down. Click 'Open'. If a warning message box shows up press 'OK'. If a message box is encountered with the content "Do you want to continue the code analysis?" - press 'No'.
We have successfully loaded the program. However the problem we face here is that it is protected with Aspack 2.12 due to which we cannot see the real code. To solve this, we are going to use OllyScript and the ASPack 2.12 OEP finder script. Go to the "Plugins' menu, and then to the "OllyScript" submenu and select "Run Script".
Look for the script and open it. The script will find the OEP (original entry point). If any window shows up dismiss it.
Quote Note: We are now on the OEP. If you are an experienced user you can dump the program using OllyDump to analyze the code with a disassembler.
Right click over the code and a context menu will appear, select 'Go to' and then 'Expression' (or use the shortcut Ctrl+G).
In the text box enter the following value according to the Deep Freeze version you have installed and press OK.
VERSION/VALUE
4.20.020.0598 / 40368D
4.20.120.0598 / 40368D
4.20.121.0613 / 4034F5
5.20.220.1125 / 4037E9
5.30.120.1181 / 4037E9
The program will jump to the line of code.
This is the line from where the password verification procedure is called. Let's set a breakpoint here. To do that right click over the line and in the context menu select 'Breakpoint' and then 'Toggle' (or press F2).
We are almost done! Now let's run this new Deep Freeze login program instance. To do that press F9. If everything went right now you should see two Deep Freeze icons on the system tray next to the clock. If Deep Freeze was configured to hide it , instead of two icons you'll see an empty icon.
Quote Note: If the icon doesn't show up is possible that you haven't written the argument three numbers correctly or that you haven't opened the right file.
Now activate the login program by double clicking over the icon while you keep the shift key pressed. If there are two icons, is important that you click over the new icon and not over the old one. The login window will appear asking for the password. Write anything in the password box and press ENTER. The breakpoing we set earlier in Ollydbg will activate and the login program will freeze.
Quote Note: If the breakpoint doesn't activate is possible that you've chosen the wrong icon. Try with the other one.
On Ollydbg press F8 to step over the function call. On the registers window (to the right of the code) you'll see that EAX register has the value 00000000. That means the password is incorrect, let's change that. Double click over the value of EAX to open the modification window. In the 'Hexadecimal' text box write 1 and press OK.
Now press F9 to continue. If everything went right the Deep Freeze configuration dialog will show up.
Sep 04, 2011 | Microsoft Computers & Internet
My msi laptop(cr420),have a webcam but it doesn't work and my wifi are not working too.
In Windows, click the Windows Icon (start), then click Control Panel.
Change "View By" to small icons, then choose device manager.
If you see yellow triangles with "!" in them next to items, then you are most likely missing device drivers for them.
You can visit MSIs support center to download the correct drivers for the cam and wireless adapter.
Link to your model is HERE
Jun 28, 2011 | Computers & Internet
I cant log on becouse I fogot my old password.
Hi.
You may reset the Windows login password without losing any Data in the Hard Drive.
You may reset the Windows login password by using the "Ophcrack" Application.
This Application removes the Windows login password without deleting any Data in the Hard Drive.
You may download the Application from the below link:.
http://ophcrack.sourceforge.net/download.php?type=livecd
Please click on the above link to download the Ophcrack Application.
I have also mentioned the link which has the detailed steps to use the Application to reset the Windows login password.
http://pcsupport.about.com/od/toolsofthetrade/ss/ophcracksbs.htm
Please click on the above link to view the detailed steps.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 23, 2010 | Toshiba Satellite A215-S4807 Notebook
I have not been able to open the yahoo.com site at all
There are several problems that could cause you not to be able to login to your Yahoo email account. Each will be discussed below.
PHISHING or HACKING
First, have you replied to any emails that requested your Yahoo email login information? If so, your password may have been changed by someone else. If you listed an alternate email address when you signed up for Yahoo? If so, on the Yahoo sign in page you can click on 'Forgot Password' and an email can be sent to your alternate email address that will allow you to set a new password. Or - you can answer the security questions to gain access to your Yahoo account as well.
PROBLEMS WITH YAHOO MAIL AUTOMATIC SECURITY
Yahoo security programs will result in you not being able to log into your Yahoo email account. Yahoo has several security features which cause many problems.
If you know that the problem is not caused by entering an incorrect user name or password, there is a work-around to get into Yahoo mail. And, it takes less than 5 minutes to set it up. However, you must use the Firefox browser to do so.
(Note: Every time I've recommended this solution to anyone for their Yahoo Mail problem, it's worked.)
The easiest way to sign into your Yahoo email account is to use Firefox as your browser and download the Webmail notifier add-on for Firefox.
With the click of a mouse, you'll be sent directly to your Yahoo email page without having to manually sign in to Yahoo mail and it will bypass Yahoo's security features that cause login problems.
Click here to download Firefox: http://www.mozilla.com/en-US/https://addons.mozilla.org/en-US/firefox/addon/4490
ADDING EMAIL NOTIFIER TO FIREFOX:
To add Webmail Notifier to your Firefox toolbar click here: https://addons.mozilla.org/en-US/firefox/addon/4490
1) After downloading Webmail notifier and re-starting Firefox, right click in an empty area on your TOP toolbar in Firefox and select, 'Customize.' (A window with icons will open.)
2) Locate the icon of a small envelope. (This is the Webmail notifier icon.) Then, drag the 'envelope icon' to your upper toolbar and click, 'Done'.
3) Once the envelope has been placed on the top toolbar in the Firefox browser, right click on the envelope icon and choose, 'Options'. (A window will open.)
4) Select, Yahoo from the drop down menu.
5) Type in your full Yahoo email address in the 'User Name' box. (ie.: my_name@yahoo.com)
6) Type in your Yahoo mail PASSWORD in the password box.
7) Click, 'Add'
8) Make sure 'Enable Login' is checked that the bottom of the box.
9) Click, 'OK'.
Now, when you want to go to your Yahoo email just click on the little envelope icon and you'll be sent straight to your email page in Yahoo. You will never need to login to yahoo again.
Tip: The envelope icon will remain gray when you don't have any unread emails in your Yahoo mail 'In Box', but will turn yellow when you do have new emails.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 06, 2010 | Yahoo Mail
Administrator password locked askesforwindowsrepair disk will gothrogh program then says has no hard drive can i reset harddrive or password dont havepassword windowswillnot display
You can recover windows password with windows password recovery tool. I know a tool named "windows login recovery" that can remove windows password without losing any data and you needn't reinstall windows OS. Download it from http://www.windowsloginrecovery.com and burn the program to a blank CD or a usb flash drive, insert the CD into the problem computer and reset your password to “Blank”. By the way, it is also useful to recover administrator password.
Dec 10, 2009 | Dell Latitude CPX-J Notebook
My yahoo messager will not load when u click on it from the starst menu. i uninstalled the messager and downloaded the latest version and installed it. now when i click on the start menu for messager or...
Try this:
Using explorer go to the c:\Program Files\Yahoo Messenger (or whatever you named it) directory + right click on the program icon (EXE file) + send to + Desktop.
Than delete the old icon as it doesn't work anymore.
Mar 02, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
