MY SANSUI SD 5000 WHEN POWER IS TURNED ON THE BOTTOM DOES NOT LIGHT UP AND I CAN NOT HEAR ANYTHING
I CANT GET THE LIGHTS ON THE METERS TO WORK & I DO NOT HEAR ANYTHING ON SPEAKERS
  • Audio Player... Master
  • 5,487 Answers
Could be just a failed fuse inside. It's replacement might restore power, but if it fails again, then there's an overload caused by a short-circuited part probably in the power supply section, where you will find that fuse.
Posted on Apr 29, 2014
Sansui HDLCD 3200 TV not powering on.
There is a problem with tuner module, try connecting with DVD if normal then the easiest way is to replace the tuner module
Nov 12, 2016 | Sansui Televison & Video
Have a sansui hdlcd32 tv. Tv lights up in the bottom right corner and will turn itself off Any assistance would be great
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 09, 2015 | Sansui Televison & Video
Sansui A-909 LED indicator(peak power meter)
Check you have 14 volts on pin 3 of the driver chip for the meter.
Apr 05, 2017 | Audio Players & Recorders
Can't get computer to turn on (compaq presario 5000)
Either your Hard drive (hd) crashed or your hd cable or port is faulty. if your software is corrupt boot with a boot disk (assume you are using XP or Vista), press R on the blue options screen. you will be given a black dos prompt screen. Type in fixboot and type Y for an answer.
Oct 26, 2009 | Compaq Presario 5000 PC Desktop
Reset Toshiba SD-5000 Dvd player to factory defaults
With most Toshibas, you could un-plug them and leave it for either 10minutes or 30minutes and it would reset. strange, I know. give it a try.
I also found this when working on a similar problem with your player, it may be relevant -you could try pressing the power button and another button..
sorry, I don't have one in front of me to test..
[[power off the player
hit the power button and immediately hold the HDMI select button
the 3 HD indicator lights will cycle and then pushing the HDMI select button will move through the resolutions.]]
Aug 31, 2009 | Toshiba SD-5000
Sansui 21" tv light on but does not switch on
Either the power supply is shot and not providing enough power to the unit. It also may be faulty system board but that would probably just cause colored lines. I would have power supply checked out with multi-meter
Jun 23, 2009 | Sansui HDLCD3200 TV
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Compaq presario 5000 startup problem
Firstly the keyboard does blink, but do you hear 2 beeps one then another a few seconds later, if not memory or graphics fault. Are you able to start in safe mode(press F8 when pc is booting up)when menu comes up highlight 'Start windows with last known good configuration' then press enter and it should re boot. The graphics card(if it's not onboard)may need to be removed and re seated, also the memory. Also check hard disk drive ide and power cable.
Jan 15, 2007 | Compaq Presario 5000 PC Desktop
57 people viewed this question
 Grubhead
Grubhead
