SOURCE: Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
SOURCE: Steps to install RICOH 2045eSP printer, scanner, copier to network computers
ok.. please kindly wait.. i will re construct a procedure for you..
BTW.. your network was wired or wireless?
SOURCE: We have a Xerox M20
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
SOURCE: KM 2550 SCANNER SETUP ON NETWORK COMPUTER
do you have the CD or the driver for the scanner? if so, use the CD to install it. if not, go to the follwoing link and download the driver
http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=18154&pcat=10569&rcid=10009&rscid=10007&x=44&y=13
I assume the other 5 computers are not running Wndows XP or don't have the same operating system??
post back if you still having problem.
please don't rate the answer till we finish the Q&A.
Thanks
SOURCE: How to add cannon iR 2016 to a network?
yes you can connect directly to a router/switch, then its just a matter of giving an IP address to machine and installing printer on PC's
Hi habib , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? scan to ftp? smb? smtp?
