Question about Kyocera Mita KM-2050 Printer
ERROR CODE C3100 - Kyocera Mita KM-2050 Printer
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 19 Answers
Check to see if the scanner lock is on lock position.. If it move to unlock C3100 Scanner carriage problem The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Posted on Nov 23, 2013
How to repair kyocera 1024mfp error code c3100
http://www.fixya.com/support/t6140540-also_need_service#solution-section
Feb 14, 2015 | Kyocera Office Equipment & Supplies
Error C3100
This code means machine's scanner home possition error. Try to check scanner home possition sensor if fixed in its possition. if not try to check scanner lamp unit movement .
Jan 20, 2013 | Kyocera FS-1035MFP
Canon Imagerunner C3100 shows error code E00012-0001
Drum motor error
Check the connector and replace the motor
Jan 17, 2013 | Canon imageRunner C3100 Copier
When i get my c3100 started i get an error code e 000013-0000 . can you tell me what the problem is
Waste toner bottle full, open front door, one screw, make sure small cut out in the neck of the bottle is clean afterwards.
Oct 31, 2010 | Canon imageRunner C3100 Copier
I am geting an error code of c3100 call for service I am geting an error code of c3100 call for...
the power is turned on or at the start of
copying using the table.
Poor contact in the
connector terminals.
Check the connection of connector YC4 on
the scanner PWB and the connector on the
scanner home position switch, and the continuity
across the connector terminals. Repair
or replace if necessary.
Defective scanner
PWB.
Replace the scanner PWB and check for
correct operation.
Defective scanner
home position
switch.
Replace the scanner home position switch.
Defective scanner
motor.
Replace the scanner motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Check if the mirror flames and exposure
lamp are on the rail. And check the scanner
wire winds correctly.
took this from a diffirent kyocera copier but it will be the same scanner related code
Oct 13, 2010 | Kyocera Copystar CS-1820 Black and White...
What is Canon C3100 error code E000008 0001
The reading of the fixing roller life counter has reached its upper limit.just reach the counter reading at svc mode.
Mar 06, 2010 | Canon imageRunner C3100N Copier
Error codes of my kyocera KM 1635
c3100 is a scanner home position error, does the scanner move when turned on with lid up? if not its the motor, if it moves then it mat be a sensor (usually "U" shaped in rear left under glass, or it could be "locked" for shipping, look for a switch on left side or under scanner unit. hope this helps.
Jan 11, 2010 | Office Equipment & Supplies
I have error code e000020-0081 on a conon c3100 copier
take drum out and clean patch sensor you may need a new drum
Nov 18, 2009 | Canon imageRunner C3100 Copier
E070-003
when i open the printer the unit will int.rot. and then the error will appear. tnx...From Canon Support Product : imageRUNNER C3100 / C3170 Title : E00351-0000 Problem
May 05, 2009 | Canon iRC3100 Printer
Kyocera Mita KM-2050 Printer Logo
405 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
