Question about Dryers
Two flashing red lights on bush tdv6w tumble dryer only new yesterday
SOURCE: TUMBLE DRYER SUDDENLY STOPPED WORKING.
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Posted on Sep 22, 2008
SOURCE: I have a bosch WTE86304GB/03 tumble dryer red
Hi the problems is not a sensor its the codenser unit. Above the water collector should be a panel on the front of your machine, open the panel and you will see the condeser.covered in fluff, simply remove the condeser and clean it under an outside tap after removing as much fluff as possible by hand. Push back into place when clean and hey presto back to new again.
Posted on Aug 11, 2010
gwhagemann
  • 114 Answers
SOURCE: Tumble dryer showing f20 and a red flashing symbol
What make and model dryer do you have?
Posted on Sep 03, 2013
whpete44
  • 484 Answers
SOURCE: my bush tdv6w vented tumble dryer is not heating up
If your dryer is an electric dryer, it is sounding like you have either a bad heating element or one of the two limit switches are open. The limit switch is an "overtemp" device to shut down the element if it gets too hot from air restriction. Lint build up in the blower and ducting is a major cause of restricted airflow across the heating element. Excessive tripping of the limit will result in an "open" limit switch and continual failure to generate heat. There should be one limit switch built into the heating package and the high limit will be located on the drum usually near the top, though there are some near the bottom of the drum as well. Any attempt to find and replace must be done with the power off as you are dealing with 240 volts.
If your dryer is gas fired, you've had a misfire probably due to a defective hot surface igniter or bad control module. Unless you are fairly capable of learning as you go, and have the basic tools for troubleshooting you probably need to call a sevice technician.
Posted on Dec 13, 2014
  • 274 Answers
SOURCE: My bush tdv6w tumble drier sounds like it is
heating element is probably burnt out
Posted on Dec 14, 2014
I have a tumble dryer bush tdv6b got from a friend not very old was working fine now its not doing anything apart from a slight buzzing noise tried the reset at the back does nothing thanks
MOST PROBABLY THE CAPACITOR BESIDE THE MOTOR NEEDS REPLACED. http://www.buyspares.co.uk/tumble-dryer/tdv6w/capacitor/product.pl?pid=4058219&shop=bush&path=864668&refine=capacitor&model_ref=8702213
Jan 31, 2016 | Dryers
Hi. My tdvcw bush tumble dryer turns but won't heat up. There's no reset button. Also the temperature light is flashing
What To Do If Your Tumble Dryer Is Not Heating Up - YouTube
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
If your tumble dryer isn't heating up, it's likely that the heater may .... helllo, i have a bosch dryer it works ...
Dryer problems: How to fix a dryer that's not heating up ...
? 3:03
https://www.youtube.com/watch?v=aFXbYp--K5g
Jun 4, 2010 - Uploaded by eSpares
For all your tumble dryer spare parts go to http://bit.ly/1LJTuT6 In this video, Rory shows us how to change the ...
Jan 25, 2016 | Dryers
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
I have a bush tumble dryer TDV6W and each time its switched on it trips the electric whats the cause?
guessing the heating element has shorted to ground . call for service.
Jan 17, 2015 | Dryers
I have a bush tumble dryer TDV6W but when I put it onto the extra heat part the botton flashes and cuts my electric out, whats wrong with it, its only 4 months old
Hi Margaret, 4 months old? warrenty problem! it may also be a shorting temperature sensor. How old is the wiring in your abode? Possibly circuit breaker faulty.
Dec 30, 2014 | Dryers
Bush tdv6w tumble dryer wont start just flashes lights and beeps
All these sound like good advice but in addition - there is a re-set button on the back of this machine, push it and see if the problem continues. If you still have the same problem after re- setting your machine please call their customer service line at 0345 640 2020.
Nov 25, 2013 | Dryers
My dryer is new it's leaking water and not drying clothes it's bush tdv6w
you have a plugged vent from the wall somewhere to where it goes to the outside , the way to tell is to unhook the vent hose run dryer through normal cycle and see if cloths dry
Nov 24, 2013 | Dryers
Dryers Logo
122 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
