Question about Baby Lock Sewing Machines
Overlocker Instructions can't get the blades in the correct position on my 4ds cooperlocker
  • 20 Answers
Bottom blade should be flush with the stitch plate. The top blade should pass below the stitch plate at the bottom end of the stroke.
Posted on Dec 06, 2013
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
I know how to open and get into my Designer Se and found the blade in part broken and not able to see hoe to reinstall the new one I have
Am guessing this is a serger. There are usually two blades in a serger (overlocker). Usually one blade can be changed by the home user, the other blade sometimes requires a technician.
Consult your owner's manual. It may have specific instructions about replacing the blades.
Nov 12, 2015 | Sewing Machines
Could you send a picture of what the blade and hook look like when they are put back correctly I think this would help. I think I may have put it back together incorrectly
The Baby Lock Imagine overlocker/serger is so easy to use and set up, you'll love it! The blade should be flush with the sewing bed when installed correctly. I'm not sure which part is being referred by "the hook", can you elaborate ... is it the loopers?? Here is the address for the manual http://pdfretriever.com/ref_sien.php?ID=2411572&lg=E&src=8
Apr 30, 2014 | Baby Lock Imagine
BLADES DON'T MEET ON OVERLOCKER
hi there
please see link to download user manual for JUKI MO-644D
http://www.juki.pl/support/HSM/Manuals/MO-654DE_manual_UK.pdf
and you must made upper and lower knife very close to cut material correctly.
regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Nov 22, 2013 | Juki MO-644D Mechanical Sewing Machine
Need spares cutting blades for bernette 234 overlocker
Bernina Bernette 334D Overlocker - recent service identified the nylon gear cog inside overlocker is broken, Do you know where I can buy a replacement.??
Jan 06, 2013 | Sewing Machines
How to set the needle plate setting nob on the janome 504d overlocker
Sorry, From Left to the Right for the blade...then 1/2 turn to offset blade out of the way to disengage....don't forget to put blade back to correct position !!
Nov 11, 2011 | Janome MyLock 644D
Where do I put the oil in my overlocker?
You don't specify the make/model - it is always best to obtain a manual for you rmachine to ensure that you are oiling in the necessary spots to ensure longevity.
Generally though, you would open up the front flap/s of your overlocker and brush out around the lower loopers and blades to remove all the lint build up before starting a new project. Then add a drop of oil to any of the metal on metal moving parts in this area. The blades also benefit from a small drop of oil.
Try sewusa.com for sewing machine and overlocker manuals.
Mar 04, 2011 | Sewing Machines
I accidentally sewed over a pin and now the moving
Disengage and then engage the blade to see if this will reset the position of the blade.
You could replace the blade - this should be in the manual or you may need to take the machine in for service as replacing the blade may or may not be all that needs to be done.
May 12, 2010 | Sewing Machines
Bernina overlocker 203 locking thread is not sewing on fabric
You need to adjust the tension for your threads. Use scraps to test sew as you adjust the individual threads to bring them into proper balance. Your manual will tell you how to do this.
May 12, 2009 | Bernina Bernette 75
Sewing Machines Logo
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
