Question about Trophy Ridge React Bow Sight
Vertical adjustment runs out of space before pin is sighted in
When adjusting the pin up/down the adjustment runs out of room before the pin gets into the desired position
What are the adjustable handles?
Adjustable handles are ideal for manual adjustments and tool-free fastening or clamping in tight spaces, RoHs compliant Adjustable Handles (Clamping Handles) provide the positioning flexibility needed for limited space applications or additional operator comfort. Available in Zinc Die Cast or Nylon 6. All ICG Adjustable Handles can be ordered with tapped inserts or threaded studs with steel or stainless steel components.For more queries on the Adjustable Handles follow the link.
Sep 09, 2016 | UTG Model 4, 15 Carry Handle With...
My rifle is shooting about five inches high. Do I turn the elevation adjustment towards "up" or opposite of "up"?
If you have a scope, the adjustment is under the top cap, and you should turn the adjustment 'down'. If you have iron sights, you would adjust the rear sight in the same direction that you want to move the bullet on the target (also 'down'). The opposite is true if you are adjusting the front sight.
Dec 26, 2014 | Optics
I have a Simmons Model ATV 4515 rifle scope. other
Your scope has 5 adjustments:
1. Eye piece focus - used to focus on the reticle.
2. windage adjustment - should be on the R side of the scope, adjusts lateral impact point.
3. Vertical adjustment - the top turret. Adjusts vertical point of impact.
4. Power ring - adjusts the magnification of the scope.
5. AO ring - Parralax adjustment - used to focus the scope at specific distances. Most markings are not exact, you should set it at the range you are shooting and fine tune focus when you look through the scope.
Sep 06, 2013 | Optics
How to sight in crosman extreme g1 pellet rifle scope
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
May 05, 2011 | Sport & Outdoor - Others
Lost string spacing adjustment screw
Not sure if you mean the vertical or length adjuster... The string "spacing" is fixed with the HipShot5.
The screws are very LIKELY metric. I would first check with a guitar shop.
Some hardware stores have metric screws. The vertical adjuster ones in this appear to be "pan head" and probably black finish which would be hard to find... however a bit of paint could make do if you can find a suitable one. Sometimes you may have to cut one to length. Getting the exart thread is important.
Feb 14, 2011 | Hipshot 5 String Type A Bass Bridge Brass...
My headlights on my 1996 Buick Roadmaster need adjusting, do you know what adjusting screws make it go up & down or in or out? I'm having a difficult time seeing the lines on the highway. How can I...
Look for a pin on top of the headlight assembly and for another on the side of the assembly, near the mid-line of the Buick. The top pin controls the vertical alignment of the headlight, and the side pin controls the horizontal alignment.Insert the screwdriver into each pin and twist to adjust the headlight beam .Be careful not to over-tighten.Its like a screw.------------- This will help.Thanks.Helpmech.
Dec 24, 2010 | 1996 Buick Roadmaster
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
Adjust headlamps 99 contur
Headlamp Adjustment Alignment
  1. NOTE: All adjustments should be made with headlamps off and at room temperature.
    Prepare the vehicle for headlamp adjustment.
    • Place the vehicle on a level surface.
    • Before aligning the headlamps, check them for faulty lenses, reflectors and blackened bulbs, and install new components as necessary.
    • Check the tire pressures and correct as necessary. For additional information, refer to Section 204-04 .
    • The vehicle must be unloaded with the exception of a tool kit and spare tire. The fuel tank should be half full.
    • Bounce the vehicle several times both front and rear or roll it a few meters so that the suspension settles.
  1. Locate the headlight adjustment screws.
    1. Vertical adjustment screw.
    1. Horizontal adjustment screw.
  1. Adjust the horizontal headlamp screw until the Horizontal indicator aligns with the "0" reference mark.
    1. "0" reference mark.
  1. Adjust the vertical headlamp screw until the bubble is centered.
    1. Bubble level indicator.
Jul 04, 2009 | 2000 Ford Contour
Vertical rolling of picture
psess the volume  up and down button together on the front pannel of the tv and then shut off the tv and it will stop scrolling.
Jan 05, 2009 | Akai LCT3201TD 32 in. LCD Television
Trophy Ridge React Bow Sight Logo
57 people viewed this question
Top Trophy Ridge Archery Experts
Andre De Beer
Andre De Beer
Level 1 Expert
Tom Chichester
Are you a Trophy Ridge Archery Expert? Answer questions, earn points and help others
