Question about Iomega Prestige 1 TB USB 20 Hard Drive
Blinking light on iomega external hard drive
The power light is blinking and my computer is not detecting the external hard drive. unplugging and restarting the computer has not solved the problem.
    Top Expert:
  • Iomega Master
  • 12,962 Answers
Try plugging the unit into another working computer. If the same thing happens then the external drive is toast. U may be able to remove the drive with within the unit, set it up as a slave, install on working computer and possibly extract any and all needed files before throwing it out.
Posted on Nov 23, 2013
  • 9 Answers
SOURCE: Iomega 250 GB external stopped working
This is really not a solution, but you should all try to connect your iomega to a imac, and use the Disk Utility (in Utilities folder), if you have any luck the hard drive will be recognized and you will be able to format it
Posted on Feb 14, 2009
lifebyguitar
  • 57 Answers
SOURCE: iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Posted on Aug 09, 2009
  • 29 Answers
SOURCE: Iomega large external hard drive doesn't show up
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
Posted on Sep 13, 2009
  • 739 Answers
SOURCE: cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Posted on Sep 17, 2009
SOURCE: my iomega external hard drive beeps when connected computer
I just bought an Iomega external Hard Drive model number SPDHDU and I couldn't get it to stop beeping when I connected it to my Mac... Then I changed the usb connection from one I had laying around for other devices, to the one it came with and now it works fine!
Posted on Apr 26, 2010
Where can i find a manual
I couldn't find a manual but maybe asking the proper question about your Iomega Hard Drive someone might get you an anser.
Most common issue is that it is not recognized so here uou have some solutions:
My iomega external hard drive not showing up in my computer but does...
iomega HDD external drive not detected LED comes ON but wont run SOLVED
Windows 7 help and support forum
External Hard Drive Not Showing Up
Aug 13, 2015 | Iomega Computers & Internet
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
My iomega external hdd has its lights on but cant be detected and does not seem to read anymore
i had the same problem. you have to be patient. open my computer through the start menu. unplug the hdd wait 15 secs and plug back in. if it still doesnt read try another port. and if it still doesnt work your hdd has a malfunction and you may need a new one
Feb 01, 2011 | Iomega 250GB USB2.0/FW 250 GB USB 2.0 Hard...
My computer refuses to recognize the external hard drive what do i do
Hello there,
What type of OS are you running ( Windows # )
What type of motherboard
Here is what i would do to start off with,
STEP ONE - Check all connections
  1. Unplug the USB data cable from the drive and the computer.
  2. Check the ends of the USB data cable to ensure that they are not damaged.
  3. Reconnect the USB data cable to the drive and the computer. Check the connections to ensure that they are secure.
    Note: If you have a Portable Hard Drive with a 2-line USB/power cable, connect both the data line and the supplemental power line (usually marked with a lightning bolt icon) to USB ports on the computer. If the status light on the drive glows steadily, the drive is receiving power. Go to step E.
  4. If you are connecting an Iomega Desktop Hard Drive, check the power supply connections to the drive and power outlet to ensure that they are secure.
  5. Restart the computer.
  6. Double click the Computer or My Computer to see if the Iomega Hard Drive is detected.
    If the Iomega Hard Drive is detected, you can now use the drive.
    If the Iomega Hard Drive is not detected, please try another USB cable and/or power supply (if available). If the Iomega Hard Drive is still not detected, continue with the next step.
if that doesn't work go to this helpful site and follow the Steps one by one to fix this problem
https://iomega-na-en.custhelp.com/app/answers/detail/a_id/1235/session/L3RpbWUvMTI5NTk4MTQwOC9zaWQvZGMzcHNaa2s%3D
don't forget to Rate
Jan 25, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My light is coming on but the computer cant find
This is a common issue with Iomega external drives. Although windows detect it as an external drive but it show up the drive.
Please check this link on how to resolve the issue . . .
Hope this helps . . .
Apr 04, 2010 | Iomega (33654) Limited Edition 500 GB USB...
My iomega drive just keeps blinking and my computer can't access it. I have two drives to store my music and I'm not sure if it was the power source or my laptop but both stopped working and all I have is...
Dear tmetal,
Hard drive anda memiliki external power source atau hanya menggunakan USB cable ?
I think it's a problem power source, power from the notebook is weakening, therefore it is not enough voltage to your hard drive.
To make sure, try connect your Hard Drive to other computer.
regards,
dm
Feb 15, 2010 | Iomega Computers & Internet
Iomega Minimax HD, no power but lead light is on. Working fine, then I turned it on today & nothing, no fan, no light but the power lead green light comes on. How do I know if its the HD or the power lead...
In your situation I would :
open the minimax enclosure, and take the hd out, (just open the enclosure, not the hd itself), and then open your desktop and connect this hd as slave (I am guessing you have a desktop with IDE hd and that the minimax has an IDE hard drive in it.... or both your desktop and the minimax has SATA hard drives) and then when you turn on your computer you should be able to see your second hd as a partition and be able to see the info in there, yet if windows does not recognize it, that means your hd is useless., yet remember you have to change the pin on your external hd to be slave or auto detect, if you let it as master your computer won't boot, bout do not worry, after you unpluges the hd from your desktop everything will be normal
p.d.
shutdown and unpluged the power cord from your desktop when adding/removing the hd.
Apr 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Dec 18, 2008 | Iomega (33215) 250 GB Hard Drive
Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Iomega Prestige 1 TB USB 20 Hard Drive Logo
404 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
