Question about Radio Communications
Nokia HF-1W pin code
Kenmore elite smart wash quiet pak hf code
i think the hf means heater fault,,,,,,,,,,,,or the thermostat
Jan 27, 2015 | Kenmore Washing Machines
Ideal icos 18 fault code HF
According to pages 47-50 of the install guide, section on FAULT FINDING, the alternating H and F indicates Flame Detection Short Circuit Error. Actions are: Remove flame detection electrode terminal from PCB. Test for continuity between 2 terminal pins? If YES, replace flame detection electrode. If NO, replace PCB. If you need more diagrams and full guide go to http://idealboilers.com/installer/wp-content/uploads/sites/2/2013/08/203318_inst.pdf
May 19, 2014 | Water Heaters
Don't understand how to connect my speakers
the 4 inputs are for biamping, (using separate amplifiers for low and high frequencies). just leave the pins in place and connect the amplifier to one red(+) and one black(-) connector on the speaker. It has an internal crossover to protect the tweeter.
Nov 20, 2013 | Audio Players & Recorders
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
HOW TO CONNECT N70 TO NOKIA HF-33W ? I HAVE FORGOT THE PASSCODE TO CONNECT THROUGH BLUETOOTH. PLEASE ASSIST
switch on your bluetooth headset . then go to settings on your phone.then click connectivity ->bluetooth-> pair device-> pair new device -> it search and ask passcode enter 0000 as pass code now it will connected still having trouble reply me
Jul 22, 2011 | Nokia N70 Cellular Phone
Will my Nokia HF-33W plug-in car speaker kit pair with my new Nokia 2690 phone?
Yes it should pair without any problem, Bluetooth has a very stable standard not related to the model or brand.
Let me know if you need additional information or support.
regards
Mar 20, 2011 | Nokia Hf 33w Bluetooth Speaker Car Kit
I want to reuse my Honda Odyssey video monitor
I have this same question. Did you get any answer?
Jul 19, 2009 | Nokia LD-1W GPS Receiver
Miller dialarc hf. foot pedal does not work
check pins a and b thats for the contacter closer. short those two out in the machine. and see if it.makes the hf come on.
Apr 05, 2009 | Welding Tools
PIN code block give me PUK code
1. Call Nokia Cust Support or take to Nokia center.
They can help
2. Get copy of Nokia Phone Tools and cable and fix yourself
Mar 26, 2009 | Nokia 6233 Cellular Phone
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
