Question about Toshiba Satellite A75-S231 Notebook
What is the polarity for the wireless card - Toshiba Satellite A75-S231 Notebook
    Top Expert:
  • Toshiba Master
  • 23,203 Answers
If you mean which way round do the aerial wires go, the answer is, it doesn't make any noticeable difference as long as they are not under tension at all.
Posted on Nov 22, 2013
Testimonial: "there is a black and white wire, one is for main and one is for aux and yes it does make a difference which way they attach"
Bunker hill camera
If you are sure that you've fastened the RG59 properly, most probably you had your power supply pins on incorrect positions. Just try to interchange the polarity of your power supply that is connected to your camera. Most analog camera's need the right polarity. "Positive to Positive" and so goes for the "Negatives".
Aug 25, 2014 | Computers & Internet
Looking fo top brand ski sunglasses and goggles. Any recommendations for me?
You can use the following site which reviews the best glasses for snowboared and ski.http://www.skisunglasses.org/top-brand-sunglasses-and-snowboard-goggle-ski-sunglasses-review
Nov 07, 2010 | Clothing Accessories
I have a Prolink wireless 900 Mgh wireless speaker system. I have just moved and have lost the plug in adapter for the transmitter. could you tell me what the adapter voltage is into the transmitter. ...
I have Prolink 900 MHz wireless loudspeakers, probably the same as yours. The transmitter is labelled on the bottom as "CAN 2579 102 1811, UNI-ART PRECISE PRODUCTS LTD". That transmitter comes with an AC/DC adapter whose output is labelled as 12VDC, 300mA, with polarity positive outside, negative inside. Note this polarity is the OPPOSITE of what is typical for AC adapters.
Sep 14, 2010 | Audio Players & Recorders
Trying to add the Dynex wireless remote to my HP Notebook
Right below the scroll button there is an eject button. Push this and slide out the cover. You will find the battery compartment. Insert 2, AAA batteries. Be careful about the polarity. It is marked. Just match the polarity. In between the 2 batteries you will find the receiver unit. Slide this one out. Insert this receiver unit into the USB port of your laptop. Close the battery compartment cover. Turn the mouse upside down. You will find an on/off (on the right side top) switch. switch it to on position. If the mouse is not detected, press the connect button below the on/off switch. Good luck.
Feb 08, 2010 | Dynex Wireless Optical Laptop Mouse...
I need a 5.1 v dc power supply for an older airport base station
There are universal multi-voltage adapters available at electronic hobby shops, they are available with various adapter plugs. Make sure you connect the adapter plug that matches the power socket for the airport AND also make SURE you connect it with the right polarity and set it for 5 volt setting. If you reverse the polarity you could destroy the airport.
Sep 12, 2009 | Apple AirPort Extreme Base Station...
Computer crashes when turn on Wireless switch
problem:sounds like polarity is switched on wireless card
Solution: remove cover plate on bottom and make sure black wire runs to Main and white wire runs to AUX
Aug 02, 2009 | Toshiba Satellite M35X-S349 Notebook
Voltage/polarity of power supply for NEC pcmcia 4 port USB2 card
If you KNOW it is 5 volts then you only need to make sure that the amp is higher and never lower. Higher amp only means it can work without getting too hot. But the VOLTS MUST BE precise. For polarity it is MOST common to have the center pin PLUS and outer NEG/GND. When I fix laptops and put the powercord wrong nothing happens. When I get it right then lights go on on PC.
Oct 31, 2017 | NEC USB 2.0 ( ) Laptop PCMCIA CardBus PC...
Wireless phone
normally the center pin is positive
Apr 27, 2007 | Uniden UIP-1868P IP Wireless Phone
Toshiba Satellite A75-S231 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
