Question about Health & Beauty
Ricoh wheelchair lift
Where do i add hydraulic oil on my lift
3 Suggested Answers
judy_kitson
  • 8 Answers
SOURCE: Hydraulic failure
Check out your Ferguson Tractors Information Headquarters, sponsored by Ferguson Enthusiasts of North America (FENA) at www.fergusontractors.org
Posted on Feb 16, 2014
tiperw4545
  • 3 Answers
SOURCE: I have a Probasics 0086 hydraulic patient lift. The boom does not raise when pumping handle. I believe hydraulic oil needs refilled. How do I add more oil to piston.
can u post pic of pump there are all diferent types but most are flat head screw take screw out fill with oil
Posted on Apr 23, 2017
John Deere 5303 lift shakes
valve is not closing properly in the hydraulics. this will cause a jump. could be the hydraulic oil is weak or has become contaminated, ie condensation is in the oil, or the seal is damaged.
Feb 08, 2018 | Cars & Trucks
I have a Mahindra 2540 tractor and can't find where to add hydraulic fluid. Help.
well u don't say what you want to add oil for... the rear 3 point hitch fill is on back near lifting arm it is orange or red small cap.... the other is next to battery red cable standing in front of battery red cable on your left cap is left from that
May 13, 2017 | Garden
How do I add hydraukic fluid?
There is a rubber plug on the side of the ram which comes out fill to the level of the hole using jack oil .
Apr 03, 2015 | Wesco Manufacturing Wesco Hydraulic...
My lift goes high without weight on it. when we lift someone it does not go same height.
It sounds to me like you have air trapped in the lift cylinder or line this is caused by in some units by lowering the unit with no weight on it after it was lifted with weight on it. If you put weight on it and run it fully up and then lower it all the way. Check the Hydraulic Fluid running the system low will cause the fluid to get extra hot and will foam witch will put air in the line. I hope this helps
Jan 09, 2015 | Health & Beauty
HOW TO ADD OIL TO FLOOR JACK?
on the side of the ram you will see in the middle a screw or a rubber plug you might have to lift
arm up and block it with a peace of wood use ether hydraulic oil or auto matic transmission fluid
don't fill it to the top its going to be time consuming but put some in and try it if it doesn't pump to
the top than add more till it works to the top
hope this helps you
bob
May 22, 2011 | Jeep Grand Cherokee Cars & Trucks
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic MerconĀ® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Ricoh 7100
fuser oil is a necessity in ricoh machine, it is entirely different consumable than toner (cyan) you dont need to repair the unit only to add oil or fuser oil, pls contact your supplier to buy one and install asap
no need to send to repairshop
Sep 17, 2008 | Ricoh Computers & Internet
Fluid adding troubleshooting
Hydraulic fluid straight from the drum, has a typical cleanliness level of ISO 4406 21/18. A 25 GPM pump operating continuously in hydraulic oil at this cleanliness level will circulate 3,500 pounds of dirt to the hydraulic system's components each year! To add hydraulic oil, and not the dirt, always filter new oil prior to use in a hydraulic system. This can be accomplished by pumping the oil into the hydraulic reservoir through the system's return filter. The easiest way to do this is to install a tee in the return line and attach a quick-connector to the branch of this tee. Attach the other half of the quick-connector to the discharge hose of a drum pump. When hydraulic oil needs to be added to the reservoir, the drum pump is coupled to the return line and the oil is pumped into the reservoir through the return filter. As well as filtering the oil, spills are avoided and the ingress of external contamination is prevented. The benefits of carrying out this simple modification are well worth the minor cost involved.
Aug 27, 2008 | Makita Industrial Quad-Driver Countersink...
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
