Factory reset skypad sp725 has frozen screen
My Skytex tablet (version sp717) won't turn on. I've tried letting it charge and it will only give me a screen that says "SKYPAD" when it's plugged it. The second I unplug it, everything goes away.
skypad Skytex - SlateDroid.com
www.slatedroid.com > Cortex A8 > Skytex Skypad
Nov 2, 2011 - 19 posts - ‎11 authors
I just received my Skypad Alpha 7" tablet yesterday. I charged up ... Will the packing or some settings in the phone tell us the version? Back to .... The problem I am having with the Skypad Alpha right now is that it won't turn on.
SKYTEX ' Android Tablets, Consumer Electronics, Windows ...
www.skytex.com/
SKYTEX Technology, Inc. is a U.S. based global supplier, developer, and distributor of ... This allows you to access your files online from your personal tablet so you won'thave to ... SKYPAD SP717 ... We make sure that your personal tablet is ready for use at home, in school, and at the office from the time you first turn it on.
[DOC]In an effort to better serve you, we've put together this email ...
www.skytex.com/download/FAQ.docx
Dec 20, 2015 | Tablets & eReaders
My screen is locked so I did a factory reset and now it is frozen, what do I do?
iF THEDEVICE HAS FROZEN AFTER A RESET IT MUST HAVE HAD A FAULT BEFORE YOU ATTEMPTED THE PROCEDURE.
aT THIS POINT YOU SHOULD REFER TO THE MANUFACTURER FOR SUPPORT IN THIS MATTER. The reset procedure is there for the end user to correct minor faults at a low level, it corrects such faults where there is no hardware fault or where the software has no fundamental installation issues. If the hard reset has not corrected the issue one or both of these issues must be present.
The manufacturer should ne able to advise you on further action
GOOD LUCK
Jun 18, 2015 | Tablets & eReaders
How do i reset my skytex skypad alpha 2 because ive forgotten my pattern lock?
How do I reset my password on my tablet?
  1. Download the re-flashing program onto your computer by visiting the Drivers & Downloads tab.
  2. Under "Firmware Downloads," select your tablet's firmware file.
  3. Select "Download" for the re-flash program and instructions for your PC. When the download is completed, follow the instructions to perform a firmware re-flash.
click on dl on your computer and install on tablet,,
SKYPAD Alpha 2 Product Support Overview SKYTEX
Jan 28, 2015 | Skytex Sxsp715a Skypad Alpha 2 7inch...
Cant turn it on unless it is plugged in then when i unplug it it goes off
No battery or battery is bad. Check that the battery is even plugged in to the socket.
Oct 28, 2014 | 01 The One SKYTEX Technology Inc. SKYPAD...
My tablet wont turn on only if it is plugged in..unplug it and it goes off
Seems like the battery is disconnected! That is why it turns off when mains power is removed!
Oct 28, 2014 | Skytex Technology Inc. SKYPAD SP725 7-Inch...
Why wont my skypad alpha 2 turn on
Hello, My SKYTEX Device (Tablet) I've had mine for about two weeks so far, well recently my SKYTEX device has been acting I don't know why?!
This morning I wanted to get into my tablet, I couldn't because it's NOT working, what it is, I'll be charging it, and thinking it turned off, I don't know why, my screen just stays black, and any advice how I do reset it as it was NEW from a computer?
Thank!
Jan 19, 2013 | Skytex Skypad Alpha 2 Android Tablet Kit
How do I reset LG P500
Factory Reset on Menu Setting
1. From the main home screen, tap menu
2. Select Settings, then Privacy
3. Select Factory data reset
4. Select Reset phone
5. Enter the password if required, then confirm by selecting Erase everything
Hope this helps,
If the phone is frozen, hard reset it through buttons
1. Turn the power off. If the phone is frozen, pull the battery out and inplace it back again
2. Hold the Home and Volume Down button
3. Press and hold the Power button until the phone turns on
4. Follow the on-screen instructions to hard reset the phone handset
The LG Optimus One P500 will then reboot to its factory fresh default state settings.
Sep 19, 2011 | LG P500 Cell Phone
 Grubhead
Grubhead
