Question about Ovens
Teba oven settings
Need to set timer for oven.
amgm
  • 32 Answers
SOURCE: trying to set oven timer
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Cheers
Posted on Feb 19, 2009
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
  • 1073 Answers
SOURCE: Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Posted on Apr 11, 2008
  • 106 Answers
SOURCE: How do you set the timer for both upper and lower oven at same ti
most ovens will only let you do a time bake for 1 oven at a time. And a min timer .Same as you can only self clean one at a time. Not knpowing what brand you have , you might want to contact manufacture.
Posted on Nov 21, 2009
blackmar
  • 235 Answers
SOURCE: I have an old electric
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Posted on Mar 03, 2011
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
Smeg electric oven timer controls
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
My electrolux EOU43002X oven bottom fan recently stopped. it also coincided with a buzzing from the timer panel. I replaced fan motor but timer wont work and the buzz still there when the timers tried
According to the convection fan which does not work, I suggest checking the main oven selector, wiring and convection fan.
According to the timer you should first set the time and then verify the correctness the timer relay. If relay is open than completely oven will not work.
Dado
Sep 08, 2015 | Electrolux Ovens
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
Mar 02, 2011 | Ovens
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for...
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
May 01, 2010 | Ovens
Nov 21, 2009 | Ovens
Timer will not go back to 0 / Light below oven setting remains on
Try and get the timer to zero, as soon as the timer is on zero the light under the oven setting knob will turn off.
Jun 24, 2009 | Ovens
Apr 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
104 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
