Question about HP LaserJet 4250dtn Printer
49, 5f11 error 4700 - HP LaserJet 4250dtn Printer
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
Error code 59.90 on color laserjet 4700
Transfer belt motor error, either a bad motor or a bad transfer belt.
Service error 4cf0 hp 4700
Try removing the JetDirect card, then see if the machine will boot and print a test page. If it works without JetDirect, then try replacing the JetDirect card.
Oct 15, 2014 | HP LaserJet 4700 Printer
In your best soulution for fixing the 59.30 error code on a hp 4700 printer it states to remove the duplex devise from the printer. what is the duplex device and where is it located
Duplex is here:
But 59.30 error (Fuser motor startup error/Black or N/A)
Follow next instructions:
Fuser motor error
1. Reconnect the connectors J4605 for the fuser motor and J1024 on the DC controller PCB.
2. Run the component test to verify that the fuser motor is working correctly.
3. Replace the fuser motor.
Aug 01, 2011 | HP LaserJet 4700 Printer
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
How do I fix error code 49.4C02 on a HP 4700 color printer?
This error code code comes because of outdated firm ware you just have to update the firm ware and solve the problem.
Update the firmware on the HP Color Laser Jet 4700 printer to version 20091125 46.120.4 or later. This new firmware resolves the issue.
Thanks.
Have a great day.
Oct 08, 2010 | Computers & Internet
Hp lj 4700 with error 41.3 unexpected paper size
Take the paper off and place the correct paper size.
If the setting is in A4 paper size please place the A4 size paper.
Thanks
Thiru
Jun 17, 2009 | Office Equipment & Supplies
HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Mar 12, 2009 | HP LaserJet 4700 Printer
HP Lasrejet 4700
This is a tray lifting error for tray 5.
See if tray 5 is not blockt
Nov 22, 2007 | HP LaserJet 4700 Printer
HP LaserJet 4250dtn Printer Logo
114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
