Question about Izzo Swami 3000 Golf GPS Unit Kit
My device will not search for the satellite connection but instead I get the error message
How do i fix my internet issue with Toshiba laptop
First thing is the operating system. What windows version you ae using has a lot to do with how to proceed. You need to look in device manager in the control panel to see what it says about your wireless device. Then you should check the error messages to see what they are
Nov 27, 2015 | Toshiba Satellite A100-S8111TD Notebook
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
Network error message using google search
You need to register this device to the app store
Dec 28, 2013 | Universal MK809 Dual-Core Android 4.1.1...
Dodge 2005 diesel truck has a Pioneer DEH 96200BT radio. The AM/FM radio part works but the sirius says "no device
Did it ever work? Sounds like you have an interface problem. Make sure the radio is connected to a Sirius XM satellite. If your device is not connected to a satellite, your device will display an error message such as "Searching for Signal."
Jul 05, 2011 | Car Audio & Video
Iphone 2g. Had cannot connect to you tube message and sorted this through cydia. Now cant receive emails and in cydia message says error refreshing data. Please help!
This can happen with Jailbroken iPhones.
Try this: http://iphoners.org/cannot-connect-to-youtube/
or Google search "cannot connect youtube jailbroken" There are several reasons that it happens.
You can load MxTube instead.
Mar 24, 2011 | Apple iPhone Smartphone
Toshiba Satellite L305D Unresponsive Touchpad
It is possibly an error with the driver. To check, go to Control Panel and then the Device Manager. Look for the section labeled "Mice and other pointing devices" and look for "Synaptics PS/2 Port TouchPad" or anything which has TouchPad in the title. If it has a weird yellow triangle with an exclamation point, there may be a driver problem. Double click on the device, choose the Driver tab at the top and choose to Update Driver. Choose to automatically search and hopefully you should find, then install, the driver.
Have you recently run any Windows updates? If so, that may have messed up the driver. Instead of choosing to update the driver, choose to roll it back instead.
My solution is only for a bad driver. I hope this helps you and apologize if it does not.
Jul 14, 2010 | Toshiba Satellite L305D-S5881 Notebook
Error: Webcam driver open fail. Problem with Satellite A305D
sounds like driver related problem, download this tool: Driver Update Software for XP Vista 7 8 update your drivers, and won't be any problem.
Jim
Jun 15, 2010 | Toshiba Satellite A305-S6845 Notebook
Error message trying to transfer songs from pc
sounds like your sd card is defective.
Look on the back of the card. did the copy protection lock get moved???
Jan 06, 2009 | Sirius Stiletto 2 Satellite Radio Receiver
Running XP on a Toshiba Satelite L40-18X
I Have satellite L40-18W-PSL4CE laptop . I installed XP . i got all drivers except sound driver. the last sound driver was running on vista is (Realtek High Definition Audio System Software Ver:R1.72) on toshiba site they said this driver soppurt vista & xp but i got nothing after installing the driver. pls help me with greatfull.
Sep 28, 2008 | Toshiba Satellite A135-S4527 Notebook
Izzo Swami 3000 Golf GPS Unit Kit Logo
56 people viewed this question
Top Izzo Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Izzo Optic Expert? Answer questions, earn points and help others
