Question about YouTube Videos
How to start smart board to operate - YouTube Videos
T-Con Board in Smart TV and network connection
The Tcon board only controls the picture on the screen. nothing else. The main board has the extra circuits to make it a smart tv. Get a main board for the smart tv and your problems will go away.
Jan 16, 2016 | Samsung Televison & Video
Operate my samsung smart tv
The problem is 1 of 2 boards. Bad capacitors on the power supply or 24V missing on the output section of it. The other common problem is the inverter boards. 1 or more FETs are shorted and the surface mount fuse is open OR the PWM IC is bad. Hope this helps you.
Mar 02, 2015 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Fisher paykel aqua smart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Our organization has a SB560, never installed it (no software) nor cables. Literally, just the Smart Board.Can someone enlighten us?
We have several SMART boards and have always looked to Smart technologies for support. The cables and software are available through the website. It will require you to use a projector, either of your own, or one of theirs. The place to start is:
http://smarttech.com/us/Support/Browse+Support/Product+Index/Hardware+Products/Front+Projection+SMART+Board+Interactive+Whiteboard/500+series
Good luck.
Mar 24, 2012 | Smart Technologies SMART Board 560 (SB560)
When writing with pen making straight line horizontally, line will scribble up and down
Confirm your computer is compatible for the latest release of SMART Product Drivers and upgrade using the Education Software Installer.
Disconnect and then reconnect the SMART Board from your computer, and reorient the SMART Board. If the issue persists contact SMART Customer Support for further assistance using SMART Board Diagnostics.
Aug 23, 2011 | Smart Technologies SMART Board 560 (SB560)
The red light is on the SMART Board 580 and we need to fix the connection so it shows green but don't know how to do this.
Find "SMART Board Tools" or "SMART Board Tools 2011" on your computer. Select Control Panel > About Software and Product Support > Tools > Diagnostics. From the menu select Service and then Start.
If the red light does not change to green, try the following steps located located here: http://preview.tinyurl.com/3qggntc
Ian Berg
Technical Support Specialist
SMART Technologies
http://www.smarttech.com/tcea
Aug 17, 2011 | Smart Technologies SMART Board 580 (SB580)
I just recieved a smart board and the tech guys attached it to the wall over a blackboard. I was told by a fellow teacher that the board would not work properly because the chalk board is magnetic is this...
There is a potential for erratic or wiggly lines if you try to draw a straight line if there is metallic material behind the SMART Board. If you notice a problem with digital ink on the SMART Board, I recommend removing the chalk board that is underneath or contacting SMART Customer Support: http://www.smarttech.com/contactsupport
Aug 09, 2011 | Smart Technologies SMART Board 580 (SB580)
Wall switch will operate door. Remote would operate door if held next to opener. Replaced logic board but remotes still will notwork at all. Wall button still works. Thanks Adrian
Did you program the opener after replacing the logic board? Press and hold the button on the remote while you press and immediately release the smart/learn button on the logic board.
Jul 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool 40 gallon energy smart elecrtic water heater. The control board binks once, by the panel means system start up failure,but we still have hot water,but every time we use the hot water it starts...
The evidence points to a control malfunction.
Call Whirlpool for assistance: 1-877-817-6750
You will need your model number and serial number located on label on side of tank.
Serial number is required because models change as the technology evolves.
Open following link to read product details about the Energy Smart, and download typical manual.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Note: Energy Smart water heater requires 10 gauge wire and 30 amp breaker.
Typical energy smart manual shows: 1 flash is start-up error, which indicates 'Power ON with no water in tank.'
This is not possible because at least the upper element would burn out, if not both elements.
If upper element burns out, this water heater will not make any hot water, since it is wired for ordinary non-simultaneous operation.
There cannot be air inside the tank since your hot water faucet is not spewing air.
http://waterheatertimer.org/How-it-works.html
Also be aware that model numbers change.
Read following account of fellow who replaced control board on his 4-year-old energy smart, and how he discovered wires are reversed on newer control boards. Be sure to ask Whirlpool about this possibility, in the event they say control board is faulty and send you new board:
http://www.fixya.com/support/t8263226-our_water_heater_doing
Feb 27, 2011 | Water Heaters
Replaced board on heater and pressure switch heil furnace still wont start is it smart valve
Hi, if you have replaced the control board and pressure switch, you need to check the sequence of operation. Starting with the inducer motor, must start up to pressurize unit box and be sure the pressure switch is closed. Even though you have replaced this switch, it may not have enough pressure to close it due to condensation in hose, a leak and so on. Jump across this switch to see if the pilot will light next. If this unit has a flame roll out switch located by the corner burner, make sure it is not tripped. Sequence of operation is, first your inducer motor will start and vent old gases and build pressure. Pressure switch will make and send signal to ignitor board to start pilot. If you have a HSI pilot, (Hot surface ignition ) it will glow. Next it gets the flame sensor hot enough to send a signal that the pilot is proved back to the board to fire the main gas smart valve with 24 volts. Go through this check as I have layed out. The flame sensor is right along side of the pilot tube and if the metal tip gets dirty, it will not fire. You can clean it with sanding cloth or fine steel wool to clean. If you go through all of these steps and it will not fire after you have made sure you have 24 volts ac at all controls in the sequence I have said, check the main gas valve across terminal C and MV for 24volts. If you have 24volts and it won't open the valve, it is faulty. Check this out for me and let me know. If no 24 volts, you have missed a safety in the sequence.
Sincerely,
Shastalaker7
A/C, Heating& Refrigeration Contractor
Oct 21, 2010 | Honeywell Heating & Cooling
YouTube Videos Logo
24 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
