Question about Car Audio & Video
Need to see how to wire amp and subs right
Plz help
  • 47 Answers
Hit me up I can help you
ksaudio-99@hotmail.com
Posted on Dec 02, 2013
3 Suggested Answers
james klgr
  • 362 Answers
SOURCE: trying to wire my amp to my subs
no thats not it you are lucky you havent burned it up like that. wire each speaker to its own source positive and negative, you loose power when you bridge an amp and use two speakers, its best to hook up without bridging you will get more volume that way.
Posted on Dec 19, 2007
  • 94 Answers
SOURCE: hey im soon getting 3 cadence amps and im wondering if i need to wire them together im going to have 10 12in subwoofers in my care and im going to run 4 subs with 1 amp at 1ohm the amps are rated sepa
i would not wire them together especially if the watage is different you can blow an amp or get a lot of interference.
Posted on Nov 06, 2013
Sub system won't play can't find in settings amo hooked up to subs yet still nothin help plz
Is the amp switching on? There are two 12v wires that have to be connected. One from a direct constant 12v supply source, and the other one from the ignition switch 12v source.Find a single 12v. supply which you can take from the lighter connection and then trace a 12v wire that runs from your ignition switch. This is mentioned in the amp manual.Double check. If the amp is coming on but no sound, then your wire connections from the amp are not correct.Or you have also connected the speaker wires incorrectly.Remmember not to connect the earth of the speaker wires to the direct earth(body of the car) but to the earth wires that are shown in the manual as this could blow the amp power IC. The earth wires of the speakers are marked -- and + respectfully and are also colour coded.You should have a RCA female plug connector from your amp to the subs. Check everything double and if still no luck their is a possibility that you could have blown an IC in the amp from wrongly connected wires. Hope this is not the case.
Apr 15, 2013 | Car Audio & Video
Subs make one very loud bang when car starts i have a kenwood kdc 528 deck and 2 pioneer 12in subs an amp
Hook it up properly to the deck remote on wire ,(Dude) End stay off the (Drugs)
Nov 22, 2012 | Pioneer Car Audio & Video
I have a alpine type r 15 inch it has two hook ups i cant figure it out i have positive two pos and neg two neg and it keeps cuting out one bridge two amp plz help plz plz
Ok, for starters. Is your sub a dual 4 ohm sub? If so, great. Is your amp 2ohm stable? If so, then great. If you are running one sub, is your amp a monoblock (single channel) amp? Are you running a two channel amp Your subwoofer is a dual voice coil subwoofer. This means that you have to have power to both voicecoils or risk damaging the voice coils. Subs are designed with dual voice coils to give it more control over the cone movement. This results in better reproduction of sound. Anyway, back to wiring.
This is for a monoblock amp (you can also bridge a 2 channel amp) Go from the positive speaker out of your amp to the positive posts of both voice coils. Then go from the negative speaker out of the amp to both negative posts on the sub. And there you have it. It's called a parallel set up. Setting it up this way just dropped the ohms load for that sub to 2 ohms. Less resistance means more power to the sub. Hope this helps
Aug 19, 2011 | Alpine Car Audio & Video
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
Jun 05, 2010 | Car Audio & Video
Power on at amp but no sound from sub plz help
Make sure that you wired the amp to the sub-woofers. Check your wiring from your amp to your sub-woofers also
Jan 18, 2010 | Car Audio & Video
Need a diagram of hw to hook 2 subs to 4 channel amp
No diagram but you can printthis out. Choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) You need to put the settings to low hertz and no high settings. Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides!). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps
Oct 08, 2009 | Kenwood Car Audio & Video
Amp dosnt work right
your amp cant handle the impedance of your subs i.e your running a 2ohm sub on a 4ohm amp!
Change the wiring on the sub so instead of running at 2ohm your run at 4
if you need to know how to wire up your sub to run at 4 then take a look at this wiring diagram
take a look at option 2
Click here
Hope this helps if so please dont forget to rate :)
Upfront Audio
Apr 13, 2009 | Pioneer GM-5100T Car Audio Amplifier
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
Alpine amp and subs questions
it will depend on how you use the 2 alpine subs,, do you know what there individual impedance is [ ohms ] and how you intend on wiring them,,,in series, in parallel, in any case you must maintain the min load in order to load the amplifier properly,,,otherwise the amplifier will operate improperly and allow DC [ direct current ] to pass and fry your subs...so what I really need is more in formation
Jul 15, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
