Question about RSQ Music
My power suply burn up can i have a diagram for it
Circuit diagram zoom
are you kidding...so if you replace it and it burns up again what are you going to do?
Jul 21, 2014 | Peavey 32fx USB 32 Channel Mixer
Peavey dpc1000 service manual
Don't do what Fred said. this is a complicated switch-mode amplifier - you'll need to pass it to someone who knows these.
after you recplace the obviously burned parts, you need to run it up in test mode and go through the test procedures until you find the other faults that caused it to fail.
Jan 24, 2013 | Music
I need meter voltage from power suply. what voltage a suply.
in this device the 48 volt(dc) is used for phantom power . and the o/p volt is from the red cable are 36volt,56volt 56volt and 75volt all in dc. take red as ref.
Mar 30, 2011 | Soundcraft *new* Soundcraft Epm8 Analog...
Soundcraft EPM12, need power suply schematic pls.
This isn't your model BUT it is likely so similar as to be close enough to work a power supply problem.
http://elektrotanya.com/soundcraft_folio_f1-6-i-p_mixer.pdf/download.html
These companies don't change designs very much between different models.
Feb 07, 2011 | Soundcraft Epm12 Analog Mixer - Epm 12
I have 2 mackie mr8's and only one does it. can you help me. basically when i turn it on after it being off for a while, the driver 'sucks' in and makes a loud buzzing sound. can you help please
For some reason the power amp is saturating to one side of the power suply rails. This can happen if :
1. Power supply looses one of the polarities.
2. The Power amp circuit loses the DC feedback and saturates to one of he rails.
3. A circuit board trace or bad solder loses one polarity to the power amp.
DO NOT permit the unit to run this way for any length of time because it will burn out the voice coil of the speaker.
The buzzing is due to the amp losing feedback and basically connecting the speaker to one side of the power supply. The ripple current of the supply causes the buzzing.
Put a 40 wat light bulb in series with the hot lead of your line cord to act as a current limiter while troubleshooting the problem. You can find the problem with only a voltmeter.
PARTS OF THE SCHEMATIC "MAY" be close to this document:
http://elektrotanya.com/mackie_hr824_studio_monitor.rar/download.html
Dec 02, 2010 | Mackie MR8 150W 8 Active Two-Way Studio...
Power suply
If the power supply fried, it is likely one of the power amp channels, usually the rearmost one has fried. There is a weak insulation thing between layers of the multi-layer circuit board that shorts.
DO NOT replace a fuse in a failed unit till problem is fixed as you will LIKELY do more damage!!!!
Nov 16, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I have a Phonic Helix Board 24 firewire MK2 When i open it all the peak led stays open I think the power suply is busted I need an expert
The power supply uses three, 3 terminal regulator chips. You should find +/- 15 volts and +5 volts DC from those. There are two fuses, one for each polarity. If one of those is blown, that would cause the problem and one would need to find WHY it blew before replacing it.
You need to find a competent electronics repair person.
Nov 02, 2010 | Phonic Helix18fw 18 Channel Mixer with...
Im looking for a curcuit diagram for the switchmode power supply in my Behringer PMP3000.
If the supply failed I can tell you which parts to replace... and if it failed there may be a failure in the power amp that caused it. You can contact be directely at fredy2 @ aol.com... put Behringer in the subject.
The supply when it fails takes out eleven components including two expensive IGBT transistors. If the rearmost amp fried, add at least four more components and a lot of work carving out burned board and wiring around the blown circuit traces.
May 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Wiring of a burns sonic guitar 1961
I have a Burns Sonic 1962. It has a complex "quirky" parallel/series wiring circuit with 3 pots, 2 switches and 2 Burns Tri-Sonic pickups. 2b4fdbd.jpg
Mar 01, 2010 | Epiphone Les Paul Studio Electric Guitar
Peavy viper 75 watt modulating amplifier stops getting power.
Your are on the right track. This fuse may look good but still be bad. once you in there all ways replace with new, it helps extend the life. 95% sure it s the fuse. If not it will need to go on the bench. Good luck DFD
Apr 11, 2009 | Peavey Music
Music Logo
18 people viewed this question
Top RSQ Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a RSQ Music Expert? Answer questions, earn points and help others
