Question about Watches
Casio pathfinder 2271
I had the batteries (qty 4) replaced and now only the barometric pressure (in mb) and temperature (C) display. None of the buttons respond, i can't get it to the watch function, compass, nohting. Even the light won't work.
  • 73 Answers
SOURCE: Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
Posted on Jan 07, 2008
  • 3422 Answers
SOURCE: Casio Wave Ceptor 2296 watch battery replacement
yes, what they said is right and will cost upto $30 and can only be fixed by them.The problem is not wid ur battery it is wid some other parts also inside it..
Since they are professional technicians for casio they charge that much.i suggest u to go for it..
Goodluck..
please don't forget to rate me as fixya..
Posted on Feb 02, 2008
  • 3 Answers
SOURCE: CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Posted on Mar 06, 2008
SOURCE: Casio Triple Sensor Pathfinder PRG60-1AV
Like anon129 I had the same problem. Those "outdoor" functions need more battery power than just telling the time and the stopwatch do. When the rechargeable lithium battery gets old and tired - which they apparently sometimes do for no very good reason - it can't provide enough power when required to, so it goes into recovery mode. It's very annoying but if your battery level indicator is already showing H the only solution is to replace the battery.
My second battery seems to be lasting better, but I'm not leaving it charging in the sun for ages this time, as I think it overheats it when the battery is full. I'm also not using the outdoor features as much, and the light hardly at all.
Posted on Mar 01, 2009
SOURCE: change battery on a casio pathfinder 2271
it needs a reset or "all clear". look carefully on the "frame", it should have a stamped arrow marked "AC" with one or more contact points at the spot pointed to by the arrow. Touch a thin wire from the top (+) of a battery to one of these contacts, repeat until the watch resets.
Posted on Oct 25, 2009
Need shell/bezel
Either send to Casio or get new watch. I go with the latter
Sep 22, 2012 | Casio Pathfinder PAG40B-2V wristwatch
When using the barometer or altimeter on my my pag 40 - 2271 it shows err. How do I fix it? Do you know what page in the users guide shows how or gives directions on how to fix?
Same problem with my SPF-40, module 2273, after a small helical compression spring, silver color, fell out. I could not determine where it is suppose to be located. It could be the barometric reference spring for sensing the barometric pressure.
Nov 18, 2010 | Casio PRG-40T-7 Pathfinder
I replaced all four batteries and i still have nothing .inside the watch it says to jumper the A C point with a twizers. what is the AC point and where.this s a casio 2271 2years old had factory batteries...
Casio battery changes are quite tricky.If you look closely at the watch module there is a place for the battery and a v-small depression usually circular on the silver module .There will be the letters AC in small writing.You need to touch the depression AC and the battery at the same time with a conductive tweezers.This shorts the module and re sets the watch.Make sure any seals go back in to protect from water/dust.
Regards
Aug 13, 2010 | Casio PRG-40T-7 Pathfinder
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
I have model 2271 PAG 40 it seems to be stuck in some kind of display mode. switching from comp to baro to alt.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 22, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
How do i change the batteries in my 2271
The safest option is to take it to a watch shop and ask them to change it for you.
While removing the back and replacing the battery,(assuming that is has a similar back to mine, which is the same make),is not too difficult, it can sometimes cause problems and since the charge for this is quite small, it is not worth taking any risk is getting it wrong. (Particularly difficult is making sure that the seal is properly made).
Considering the cost of you watch I would advise against doing it yourself.
Jan 25, 2010 | Casio PRG-40T-7 Pathfinder
6 year old Casio no. 2271 has ceased responding to buttons
Hi, If you buy some new batteries - i.e. from ebay (very cheap) and replace the old ones - or take tyhe watch into a jewellers and get them replaced (appx. £15) this should do the trick. The batteries should be replaced every 2 years.
Jan 02, 2009 | Casio PRG-40T-7 Pathfinder
Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
How to get casio sea-pathfinder working after replacing batteries
This certainly put me on the right track,but i found on my pathfinder mod 2271 that the four brass dots located down in the hole were unacessable with standard flat head tweezers so I inserted a small sewing needle and touched one of the brass dots while bridgeing the distance from the needle to the positive (+) surface of one of the four batteries with tweezer legs.
Nov 19, 2007 | Watches
Watches Logo
23 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
